February 02, 2026, 01:30:29 PM *
Author Topic: Stripping Wax  (Read 1534 times)
Steve K (IA)
Cedar Rapids, Iowa
« on: May 27, 2011, 09:01:45 PM »
What is the best and easiest way to strip wax off without hurting the paint or custom pin-striping?
States I Have Ridden In
« Reply #1 on: May 27, 2011, 11:38:45 PM »
There is paint prep, used to take off oils and wax on paint before painting.
9Ball
« Reply #2 on: May 28, 2011, 03:07:20 AM »
simple green will also remove wax and oils
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
X Ring
VRCC #27389, VRCCDS #204
« Reply #3 on: May 28, 2011, 04:17:28 AM »
Simple dish washing soap also removes waxes and oils.
Marty
shank
Morristown TN.
« Reply #4 on: May 28, 2011, 06:15:39 AM »
mcguires, 3 step you can get it at any auto parts store. i have used it several times and it always comes out brillant.
rodeo1
« Reply #5 on: May 28, 2011, 06:34:25 AM »
simple answer -- go to your local auto paint store, ask for a quart of wax and grease remover. strips it in one application, will not damage anything. wipe on wipe off solvent, super easy, super fast.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #6 on: May 28, 2011, 08:50:11 AM »
I asked for an easy way, and you all came through. Thanks!   cooldude  I bought a new product and all wax needs to be removed before applying the new.
« Reply #7 on: May 28, 2011, 08:53:16 AM »
A lot is going to depend upon the paint used by the guy doing the stripe and whether or not there is clear coat over the work.
The Honda paint is the least to worry about.
I'd suggest just continue to wax and not to worry about it!
