February 02, 2026, 01:30:21 PM
Bike won't run right
Topic: Bike won't run right (Read 1471 times)
Fawkesy
May 28, 2011, 02:50:16 PM »
Hi. Posting for my friend. 2000 I/s.
Bike will start right up when cold, run for 10 minutes (exactly each time) then start running rough.
Let bike cool for 10-15 mins, then try again and exactly at 10 minutes runs rough.
No vaccum leaks, no carb / fuel problems. Fresh gas. Checked all coils - okay.
Can anyone help us out?
Thanks so much.
Mr.BubblesVRCCDS0008
Re: Bike won't run right
May 28, 2011, 03:14:27 PM »
Pop the tank cap open and see if it stay running longer, maybe be the vent tube is plugged and pulling a vaccum on the tank.
Fawkesy
May 28, 2011, 04:07:30 PM »
Thanks Mr.Bubbles.
Tried that...wasn't the issue.
We just tried the bike (with gas cap closed) for 35 minutes and she ran good!...now i'm really stumped.
May 28, 2011, 06:01:35 PM »
Sounds like it may be a tear in the vacuum diaphragm in the fuel valve. The valve partly opens allowing fuel to flow at a reduced rate. If the problem improves with a full tank of gas it strengthens my theory. Higher fuel pressure pushing past the partly closed valve is better able to adequately feed the engine.
