February 02, 2026, 01:30:44 PM *
Author Topic: Lost my Key to my 99 interstate.  (Read 1812 times)
Maddog vrcc#508
Belly tank, heated gear you can go any where.
Seattle Wa, The "Vermin Nation"
« on: May 29, 2011, 10:09:10 AM »
I am in the final stage of getting my 99 Interstate put back together and I have misplaced the keys.  Can someone out there help me to find the information I need to have a new key made?  I am told there is a code on the back of the ignition, pulled mine off and can't seem to find it.  If I can get the code there is a Honda shop in Albuquerque that can make me a key and send it to me.  I live in Seattle and all the Honda shops here just want to order a blank and send me on my way.
Thanks in advance, Mike.
                    In the Vermin Nation
« Reply #1 on: May 29, 2011, 10:22:15 AM »
The place we all lose our key from time to time is in the seat lock (underneath);  is it there?
Misplaced, rather than lost..... but the same result.   crazy2
If not, if you have key code, call a local lock and key outfit and ask, they should be able to make one (three actually).
« Last Edit: May 29, 2011, 10:25:03 AM by Jess from VA » Logged
« Reply #2 on: May 29, 2011, 10:22:51 AM »
Find a good locksmith locally and have him cut ya one.
Otherwise I think ya have to take the title and etc to the dealer to have it cut.
eric in md
« Reply #3 on: May 29, 2011, 10:38:28 AM »
 cooldude   +2 look in the center panel aka seat lock ..
« Reply #4 on: May 29, 2011, 01:31:10 PM »
The key code is on the original key, I'm not aware of anywhere on the bike that has the code written down. Only likely way is to take a lock to a good lock smith and have him make one.
As for the dealer, I know with the registration on my CAR I can get a new one cut at the dealer. Maybe they can do the same for a MC, or at least get you the code, then you can get one from the lock smith. My local smith is able to make from the key code. $16 for one.
« Reply #5 on: May 29, 2011, 01:52:23 PM »
Maddog...is the trunk on that IS open....or closed... ???
Mr.BubblesVRCCDS0008
« Reply #6 on: May 29, 2011, 03:22:44 PM »
If you pull lock set out of the hardbag or trunk a good locksmith can cut you a key.
PhredValk
Edmonton, Alberta, Canada
« Reply #7 on: May 29, 2011, 03:50:48 PM »
Also check the steering lock. Once you figure out the 3 digit code (hopefully after finding your key) write it down somewhere. I have mine in a notepad on the PC and written down in my wallet.
Fred.
VRCCDS0237
Big Mike
I can not remember my last bad day
Taylor MI
« Reply #8 on: May 29, 2011, 04:14:08 PM »
The different key slots on the bike use different parts of the key to lock or unlock. so if you get a key made from say the gas cap, the key may not work in all of the other cylinders. If you look on your ignition switch there will be a code behind the chrome cover that you can take to the dealer and they can cut you a new key. The code generally has 2 letters and 2 numbers. This will get you the correct key for the bike. DO not ask me how I found this out. I will tell you it was about 300 miles from home, lucky for me only about 2 miles from a Honda dealer.
Big Mike
VRCC 23871
VRCCDS 0200
With GOD and a good attitude, there is no circumstance that I can not overcome.
Red Diamond
Beaumont, Texas
« Reply #9 on: May 29, 2011, 07:33:36 PM »
If you can PM me, I'll tell you how to find the key code. I also think this was discussed before on this board. Do a search.
