February 02, 2026, 01:30:46 PM *
Author Topic: Question for you 1800 Goldwingers  (Read 1912 times)
Wolfgang1952
Mt Hermon, La
« on: May 30, 2011, 04:43:21 AM »
I know this isn’t about a Valk.    I’m rebuilding the front forks on a 2002 1800 Goldwing for a friend of mine.    He has the Honda Shop Manual.    My question is how much oil do the forks hold.    In the Honda shop manual it says 8 oz. per side.    When I went to Honda to get the new seal and other parts plus oil.    Boy was there sticker shock, 22 dollars a quart.    The Guy in back said I needed 17 oz. per stick.    That’s what it said in his book.     My book said 8oz per stick.    Which one is right?
VRCC # 4391
The South Shall Rise Again
Not enough guns and definitely not enough ammo
Wolf
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: May 30, 2011, 05:13:45 AM »
You might want to ask this question on one of the Goldwing forums.
Marty
« Reply #2 on: May 30, 2011, 07:22:29 AM »
Well, the 17oz per stick is way more right for the dealer, he bout doubles his money.
« Reply #3 on: May 30, 2011, 08:26:11 AM »
I just rebuilt my '05 1800's forks last week. The new fork springs I bought came with a liter of 10W fork oil. Both forks took exactly 1 liter. Each side was slightly different but after you get the right amount in, you should be 5 inches down from the top of the fork tube. Left side is 17.9 oz. Right side is 16.4 oz.
« Reply #4 on: May 30, 2011, 10:09:53 AM »
There you go! Even Goldwings questions answered correctly on the Valkyrie Riders CC forum!
Wolfgang1952
Mt Hermon, La
« Reply #5 on: May 30, 2011, 11:45:04 AM »
If it takes 16.5-7 oz per stick why does it say 8oz in the regular Honda Shop for a 2002 1800 Goldwing Manual he bought when he bought his bike?    I know in my Valk it only takes 8oz.    Least that what it says in my shop manual.
VRCC # 4391
Wolf
Daniel Meyer
The State of confusion.
« Reply #6 on: May 30, 2011, 11:54:44 AM »
That's not correct. The Valk takes nearly a quart...
CUAgain,
Daniel Meyer
X Ring
« Reply #7 on: May 30, 2011, 12:47:45 PM »
I just checked my shop manual and Valkyries take the following:
                          Left              Right
Standard/Tourer    25.2 oz         22.7 oz
Interstate            24.8 oz         22.6 oz
Marty
Snoopy
multi year nam vet AC130 (puff)
Jacksonville Beach, Fl/ Pickens,SC
« Reply #8 on: May 30, 2011, 12:59:00 PM »
Make sure you pump the right side dampering rod  after you put fluid before you measure to make sure you have all the air out of the dampering rod
Multi year nam vet AC130 (Puff) All gave some, some gave all
DFragn
« Reply #9 on: May 30, 2011, 02:17:44 PM »
To help clarify that measurement on the GW, since it would make a huge difference.
What's the tube status of the 5" from the top?
1.) Fully compressed on the table.
2.) Fully extended
3.) All components installed & mounted, both wheels on the ground...bike lift or center-stand.
« Last Edit: May 30, 2011, 02:19:29 PM by DFragn » Logged
Snoopy
« Reply #10 on: May 30, 2011, 02:39:36 PM »
Springs and spacers out forks compressed
« Reply #11 on: May 30, 2011, 06:16:10 PM »
2.) Fully extended
The OEM service manual has the right condition to measure. The springs are not installed yet and the tubes are compressed all the way. After pumping the dampener rod to fill it, then measure 5" down. The left side needs no pumping. After measuring, then install the springs, spacers and top caps.
