February 02, 2026, 01:31:29 PM *
Author Topic: rear tire/ maintenance ?  (Read 1734 times)
big sky
Pensacola, Fl.
« on: May 30, 2011, 09:12:44 AM »
I am about to order a new rear tire for my 97 Std.
What other things should I change/inspect while in there. (especially things that would need to be ordered)
Sky
Earl in Pensacola
« Reply #1 on: May 30, 2011, 09:25:28 AM »
I guess that it depends a lot on what was done during the last rear tire install AND how many miles you got out of the tire.  As for my self, I just ordered a new Cobra after getting 23K out of the one that's still on.  So, for sure I'll have to pull the shaft for cleaning, inspection and relube.  In as much as I'm a pretty "easy" rider and I know that the wheel bearings are smooth and there are no visible leaks, I'll just be cleaning and lubing the various gears/splines/thrust washer and very likely will not need new "O" rings and then checking the "pumpkin" 80/90 wt lube level.  The last go-a-roung (23K), Jeff and I installed new bearings/seals/"O" rings etc. Good luck
big sky
Pensacola, Fl.
« Reply #2 on: May 30, 2011, 09:44:43 AM »
it is the tire that was on the bike when I bought it.  So all previous maintenance is unknown.  Guess I will just have to remove it and see what everything looks like.  Who in Pcola do you get to mount and balance them for you.
Sky
PhredValk
Edmonton, Alberta, Canada
« Reply #3 on: May 30, 2011, 09:52:57 AM »
Read the Shoptalk article on tire changes and make sure you have the 3 O-rings. I just did mine and it's really not all that hard.
http://www.valkyrieriders.com/shoptalk/TireChangeSplineLube.htm
Fred.
« Last Edit: May 30, 2011, 10:07:12 AM by PhredValk » Logged
VRCCDS0237
« Reply #4 on: May 30, 2011, 09:58:31 AM »
Yes, if history is unknown, then for your peace of mind and the bikes longevity, do eveything from the u-joint back (not the swingarm bearings).
Like already mentioned by Phredvalk, read the article and also do some searches, just to get some other feeb back on a job.
Remember, it's getting hot out now, so don't forget to keep the mechanic well hydrated too....
« Last Edit: May 30, 2011, 10:46:45 AM by gordonv » Logged
Earl in Pensacola
« Reply #5 on: May 30, 2011, 11:07:12 AM »
The last time I hd it done (here in P-cola), I carried the rear wheel into the dealership and they charged $35.00 to mount, balance and hand it back to me.  Call them 850-456-6655, it MAY still be the same.  There is a tire sales shop in Milton that has done a mount/balance a number times for various riders of both Valks and wings for $15.00.  The tire shop name is "Gaines"-850-995-0625.
X Ring
VRCC #27389, VRCCDS #204
« Reply #6 on: May 30, 2011, 12:37:42 PM »
I HIGHLY recommend you change all three o rings every time you remove the rear wheel for servicing.  To do otherwise is risking a $12-1500 repair bill to save what, $3.  That's penny wise and pound foolish.   uglystupid2
Make sure you grease the o rings and fill their grooves with grease also.  What you use whether it is Honda Moly 60, Guard Dog or a high quality wheel bearing grease is up to you.  If you do a search you find all kinds of opinions.
If you haven't already, download Kulow's Maintenance Guide from Shoptalk and at least look over all the articles on final drive maintenance.  You can also go to http://valkyrienorway.com/ and download a scanned version of the Honda Shop Manual.
Marty
Dave Weaver
Seymour, IN
« Reply #7 on: May 30, 2011, 01:31:04 PM »
The 3 O-rings, left and right side bearings and dust seals, thrust washer, wheel dampers, and Patchboy 90* valve stem are the parts I keep around for a rear tire change. I don't change all of them out every time, but have them if needed.   Oh, and a 205/60-16 Goodyear Assurance Triple Tread.   cooldude
Do unto others as you would have them do unto you.
« Reply #8 on: May 30, 2011, 02:25:07 PM »
Just recently got done with that rear end sevice thingy. If you know which end of a tool to hang onto can read and apply what you've read-you can do it yourself. It ain't rocket science. uglystupid2 It's a little bit if wtrenchin on YOUR ride that when you do get done with it-ya get this nice warm fuzzy feelin. 2funny It ain't that difficult and besides-doin it your self-ya ain't financing the stealers golf outings. crazy2 RIDE SAFE.
NITRO
Eau Claire, WI
« Reply #9 on: May 30, 2011, 05:35:45 PM »
You can get a set of all three o-rings from carolina bike and trike (enough for five changes). You'll need to order the thrust washer elsewhere.
http://www.carolinabikeandtrike.com/ORings.htm
When in doubt, ride.
