August 24, 2025, 06:39:52 AM *
Author Topic: Removing brake pads  (Read 1592 times)
billyjakester
« on: June 06, 2011, 06:55:03 PM »
Std. 2000 Valk.  Each caliper has a Hanger Pin that retains the brake pads in place plus a Pin Plug that is threaded on top of the Hanger Pin in the same hole.  Last time I removed these pins I didn't apply any anti-seize and now these Pin Plugs have taken a set in the aluminum casting.  Penetrating oil(s), tapping lightly with a hammer, etc. hasn't help.
My next step is the drill a pilot hole in the Pin Plug and try an EZ-Out, but if anyone has better suggestions I'd appreciate the help.
thanx,
bill
« Reply #1 on: June 06, 2011, 07:12:06 PM »
If you removed the caliper from the fork before trying to remove those plugs, thats your problem.  Re-install the caliper get a PROPERLYfitting screwdriver, place it in the groove, tap on it with a small hammer and then apply heavy pressure and torque, it will come loose
« Reply #2 on: June 06, 2011, 08:14:51 PM »
I went out and bought an impact driver, the manual one you twist and then hit with a hammer.
Seems the head comes off, and you can put different size socket drives in also.
X Ring
VRCC #27389, VRCCDS #204
« Reply #3 on: June 06, 2011, 08:29:45 PM »
This is what I had to use on the rear caliper of my I/S to get the pin plug out.  I had to remove the caliper from the bike and take it to my workbench.  Soaked it in penetrating oil overnight then took the impact driver to the pin plug.  The pin and banjo bolts were also seized.  Used a hammer on the end of a wrench to break them free.  Put anti seize on everything but the banjo bolt.  If the rear was this bad, I hate to see what the fronts will be like.
Marty
« Reply #4 on: June 07, 2011, 09:12:25 AM »
The important and operational word
as stated by Chris:
Properly fitting screwdriver
All screwdrivers are not equal!
art
Grants Pass,Or
Grants Pass,Or
« Reply #5 on: June 07, 2011, 04:09:35 PM »
Use a metric screwdriver.Just joking
X Ring
« Reply #6 on: June 07, 2011, 08:09:32 PM »
Was messing around on the Valkyrie Riders Forum and they had a link to Dag's site with instructions on how to turn a 6mm socket head screw into a socket head pin plug.  This looks like it worth a shot.  I'm going to try to make a few this weekend.  I'll let you know how it goes.
Basically you take this:
Cut 10mmx1 threads into the head:
Then cut off the shaft:
Here's the link:  http://www.valkyrienorway.com/Techpinplug.html
Marty
wekieboom
Frisco
« Reply #7 on: June 08, 2011, 06:14:44 AM »
This made me laugh.  Thank you
< boom >
Dirty Dave
Montreal, Canada
« Reply #8 on: June 08, 2011, 10:33:11 AM »
Brilliant mod. Thanks!
bscrive
Ottawa, Ontario
« Reply #9 on: June 08, 2011, 12:18:07 PM »
Man, all mine came out without a problem.  Why do some people think that you have to tighten something so hard when it is just a cap.  The old 'tighten it until it snaps it off and then loosen it up a little' mentality I guess.
JetDriver
Columbus, OH
« Reply #10 on: June 15, 2011, 08:50:59 PM »
This probably won't help billyjakester anymore, but I just got through the same problem.  24 hours of penetrating oil and tapping my screwdriver with a hammer and nothing.  I got my wife's hairdryer and started heating up the caliper.  I used a small piece of wood to try to shield the pin plug from the heat, so it wouldn't heat up as fast as the caliper.  2 minutes later, the pin plug was out.   cooldude  And it wasn't a situation of having been screwed in too tightly, unless Honda did it at the factory.  I bought it new, and at 49000 miles, this is the first pad change!  laugh  The pin plug goes back in with antiseize!  Smiley
« Last Edit: June 15, 2011, 09:52:38 PM by JetDriver » Logged
