February 02, 2026, 03:16:00 PM
Battleaxe 200 series tire pressure survey
Topic: Battleaxe 200 series tire pressure survey (Read 2423 times)
June 12, 2011, 11:43:23 AM »
When the tire was mounted last week before I left for Americade it was filled to 40lbs
This morning, now that I am home and the ride-on finally arrived in the mail, I let the air out to install the 12oz of ride-on and put in 41lbs of pressure with my little air compressor.
I know many have used this tire with good results but am curious what pressures did you run in the tire and how long did it last before you got down to the wear bars or experienced cupping
I am diggin this tire, but then again any new tire feels better than the old one
Yogi Berra (Don't send it to me C.O.D.)
Warlock
Magnolia, Ms
Re: Battleaxe 200 series tire pressure survey
June 12, 2011, 03:26:56 PM »
I really liked the tire and ran around 40 to 42 lbs. Tire only lasted a little over 7000 miles. If the tire would have made 10000 I would be running them. Too much money and not enough miles. The roads down here are hard on any tires. A lot of gray rock slag in our blacktops.
David
X Ring
VRCC #27389, VRCCDS #204
June 12, 2011, 11:28:46 PM »
Quote from: Warlock on June 12, 2011, 03:26:56 PM
David
Ain't that the truth. Of course it doesn't take long to wear off mold release on chip and tar roads either.
Marty
quexpress
Montreal, Québec, Canada
June 13, 2011, 05:36:12 AM »
42lbs
... as long as the other brands I have used.
I still have a full deck.
I just shuffle slower ...
June 13, 2011, 05:50:47 AM »
Didn't last as long as a Dunlop, lasted longer than a Metz. About average I'd say. Did ride well, though. 40 psi for me.
hoser
boss hoss bill
June 13, 2011, 08:53:07 AM »
FWIW
I have one of these on my 09 V Max (came stock with it.)
Great handling in the twisties, good ride, ran mine at 42 PSI.
Got a little over 5k on it, and it's almost worn out, maybe 6k if I'm lucky.
Might go to Metz 880's next, if not, I'll stick with it. It's a good tire.
Bill
rodeo1
Reply #6 on:
June 13, 2011, 04:20:27 PM »
oh my ! too much pressure on me -- must be the PTSD
Tundra
2014 Valkyrie 1800
Seminole, Florida
Reply #7 on:
June 13, 2011, 05:00:18 PM »
Quote from: boss hoss bill on June 13, 2011, 08:53:07 AM
FWIW
Bill
That is one AWESOME motorcycle
...If I had the cash, I'd own one
