November 23, 2025, 05:00:45 AM *
Author Topic: Do you know about Truck Stack Pipes?  (Read 2794 times)
Paxton
So Cal
« on: June 14, 2011, 01:55:51 AM »
Dragonfly got stacked up last night .  Wink Cheesy crazy2
See before / after pictures:  Roll Eyes Cool coolsmiley 2funny
https://picasaweb.google.com/103917731019176896112/4TruckStackPipesBeforeAfterPhotos?authkey=Gv1sRgCLPpuLLMxrjV2QE#5617986330140547714
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
ricoman
Sarasota, FL
« Reply #1 on: June 14, 2011, 09:35:35 AM »
what are the pipes from?
interesting look, how are the chrome mufflers held in the pipes?
« Reply #2 on: June 14, 2011, 02:30:37 PM »
Sure do.  hoser   cooldude
bscrive
Ottawa, Ontario
« Reply #3 on: June 14, 2011, 05:46:26 PM »
I put some on a few years ago and now they have turned a golden colour.  I am not too pleased with them.  They look nice...at first.
bigdog99
1/1/2011 86,000 miles
Kouts Indiana
« Reply #4 on: June 14, 2011, 06:10:32 PM »
yep over here too. took mine down coolsmiley
VRCC#31391
VRCCDS0239
PhredValk
Edmonton, Alberta, Canada
« Reply #5 on: June 14, 2011, 08:33:54 PM »
I think the golden color would look nice on my green/silver I/S, the silver has a slight golden hue to it.
Fred.
VRCCDS0237
Paxton
So Cal
« Reply #6 on: June 15, 2011, 01:07:00 AM »
Not until I started the installation did I realize that the existing aftermarket pipes are less than 4" O.D.  ??? The original baffles are gone.  Shocked
So all we did was to slide them stacks over the existing pipes. Drilled two 1/4" holes and bolted them to the OEM brackets...  into the stacks,
reaching the mounting bracket nuts on the existing pipes.  cooldude The entire job took us 45 minutes and two beers!  Cheesy
Here are some photos of yesterday's show off... cruising through Griffith Park in Los Angeles.    Wink
SUGGESTION: Set the Slideshow at the fastest speed (1 Second).
https://picasaweb.google.com/103917731019176896112/GRIFFITHPARKOBSERVATORYAndMore?authkey=Gv1sRgCKrOsa6P1OS0cA
J. Paxton Gomez
So Cal... 91205
rmrc51
Palmyra, Virginia
« Reply #7 on: June 15, 2011, 03:38:51 AM »
Speaking of Truck stacks, I also have them on my trike and love the look. But I really would like to quiet her down a bit. (You can wake up the dead in the early morning!)
At present, I have 12" glass packs inside the stacks. Is there anything I can add to the end to quiet her down more??
VRCC # 30041
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #8 on: June 15, 2011, 04:39:49 AM »
You can weld a 2"  threaded coupling from your local hardware store to the output end of your glasspacks. Then you can get some threaded straight pipe and screw it in or out to suit your needs, quiet or loud. You can play with it even more to change the pitch by drilling holes.
  You could also go with a longer Glasspack? I know 18" is available.
And of course...finish it off with Grumpy's tips cooldude
« Last Edit: June 15, 2011, 06:16:47 AM by Tundra » Logged
« Reply #9 on: June 15, 2011, 04:43:05 AM »
Get Grumpy's tips for your stacks, great workmanship and polished.  They reduce the volume and sound great. He is on this board,  user name grumpy. They are on mine pictured above.  Hoser
« Last Edit: June 15, 2011, 04:45:10 AM by Hoser » Logged
rmrc51
Palmyra, Virginia
« Reply #10 on: June 15, 2011, 05:48:44 AM »
I already have them Hoser. I believe they came in two different openings. Not sure what the diameter was. All I know is that I have the larger size. Do you think the smaller opening would reduce the sound significantly? If so, I'll try and get in touch with Grumpy to see is he has a set.
VRCC # 30041
Motse
« Reply #11 on: June 17, 2011, 01:04:53 PM »
Mine are turned out. I like them, These have 12 " glasspacks, And it is pretty loud.
If I could figure out how to insert the pics..I would
Paxton
So Cal
« Reply #12 on: June 18, 2011, 12:19:39 AM »
Here is an updated view of these puppies...  Cheesy Grin cooldude
https://picasaweb.google.com/103917731019176896112/BlackWheelsTruckStackPipes?authkey=Gv1sRgCLGw9YWk3cS0dw
J. Paxton Gomez
So Cal... 91205
