February 02, 2026, 07:52:26 PM *
Author Topic: Darkside Problem  (Read 4382 times)
RainMaker
Arlington, TX
« on: June 14, 2011, 07:22:31 PM »
I just installed my second Darkside tire.  I was running a Goodyear Assurance TT 205-60-16 and went with the General Altimax v-rated 205-60-16 this time.  The Goodyear had rubbed enough that the lettering was gone on the right side when I changed it.  Took the Altimax for a quick 10 mile ride and smelled rubber.  Got home and there is rubber dust on the inside of the wheel, plus the tire, pumpkin, wheel and swingarm are all hot to the touch.  Not burning, but hot.  There is a sheen on the right side (pumpkin side) that wasn't there when I left.  Tire pressure before I left was 40 lbs.  The nut cage mod has been done as has the washer mod.
I put it back up on the centerstand and the tire spins freely.  No grinding sounds.
I just replaced gear fluid, serviced the spines, etc.  No play in the bearings I could find. Felt fine while it was going down the road, no strange noises.
Any ideas?
« Last Edit: June 15, 2011, 07:52:48 AM by RainMaker » Logged
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
PhredValk
Edmonton, Alberta, Canada
« Reply #1 on: June 14, 2011, 08:11:07 PM »
At any size; 50's are wider than 60's that are wider than 65's. Have someone check the clearance with you sitting on the bike?
Fred.
VRCCDS0237
Brad
Reno, Nevada
« Reply #2 on: June 14, 2011, 08:45:10 PM »
If you have rubber dust it is rubbing.  Pull the wheel and I am sure you will see something polished where it is touching.
Disco
Republic of Texas
« Reply #3 on: June 14, 2011, 08:59:31 PM »
I ... went with the General Altimax v-rated 205-50-16 this time.
RM, I only see the v-rated Altimax in 205/60-16.  Is the 50 at typo?  Wizard had told me before the reason he likes the Altimax is the soft sidewall.  When we did Stormrider 65's new Altimax a couple of weeks ago at Hogheads Wrench Party, it was noticeably softer than the tire I'm riding.  What pressure did you run on your test ride?  Perhaps you could bump the pressure up a bit to minimize the squish.
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
X Ring
VRCC #27389, VRCCDS #204
« Reply #4 on: June 14, 2011, 09:07:24 PM »
Punisher once had a problem that only turned up when he turned left.  The tire would rub on the welded in nut for the bolt you did the washer mod on.  He pulled the wheel, saw where it was rubbing and ground it down to the end of the bolt.  It doesn't rub anymore.
Marty
« Reply #5 on: June 14, 2011, 10:12:31 PM »
My ultimax 205-60-16 is close to the swing arm on that side-close but no rub. H rated and i keep it at 44 P S I. No rub issue at all and i ride the snot out of it. Bet when you pull that tire out of the swing arm you will find the rub. RIDE SAFE.
« Reply #6 on: June 14, 2011, 10:43:04 PM »
Fred.
Excuse me, I know I'm drunk, just had one beer (1 2 liter bottle, bottle my own), but the designation 50, 60, etc, refers to a % of the tire width to hieght. So a 200mm wide tire with 50(%) = 200x100. So a 60% tire is NOT wider than a 50% or a 65% tire if the width is 200. That refers to tire hieght from width.
Your tire is rubbing on something. People have mentioned that it can rub on the swingarm. A not so easy method might be to remove the rim fromthe bike, and inspect the inside for wear.
sugerbear
wentzville mo
« Reply #7 on: June 14, 2011, 10:45:29 PM »
if you find it's rubbing on the "nut cage mod" grind it down smooth and replace the bolt with a carriage bolt from the inside. Smiley
sugerbear
wentzville mo
« Reply #8 on: June 14, 2011, 10:50:58 PM »
Fred.
went to tirerack.com and pulled out a tire. look at the sect. width of the 205-55-16 and the 205-65-16. there is a difference in the width.
http://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=HydroEdge+with+Green+X
select specs Smiley
« Last Edit: June 14, 2011, 10:52:40 PM by sugerbear » Logged
X Ring
« Reply #9 on: June 15, 2011, 01:16:10 AM »
And select the correct tires!
Marty
MP
North Dakota
« Reply #10 on: June 15, 2011, 03:06:40 AM »
I would guess you are rubbing on the bolt left on the nutcage.  I had to take mine out, and I replaced it with a carraige bolt from the inside.  If you can slip a business card between the tire and the swingarm at rest, it will never rub the swingarm.  I run 28# in my Altimax.  Any squish is only on the bottom of the tire, never on the side.
Checking clearance while on a lift does no good.  Look up inside the fender, and I will bet the bolt/nut looks shiny from rubbing.
MP
"Ridin' with Cycho"
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #11 on: June 15, 2011, 04:55:34 AM »
Did you do the nutcage mod.? If no do it, here's the link http://lifeisaroad.com/stories/2005/08/24/valkyrieRearFenderNutCageMod.html
If you already did it, I also had to intall a carriage bolt (low profile pan head) backwards. Bolt head on the inside of the fender. That still didn't do it for me. Then I had to shim my fender rail. This was VERY EASY and took only minutes. I was good to go cooldude
  Your problem is common with some darksiders and is an easy fix. Look at your tire and rear fender from behind and measure the clearance left and right of the tire. Mine was off center by about 3/4" Some bikes are right on the money, others not so much. I had a nice tutorial from "Easygoer" on the Florida board with pics for the fender rail shim. Link made by Easygoer...http://rides.webshots.com/album/558419637qsIyod?vhost=rides
 Don't sweat it your almost done cooldude
  OK I just re-read your post and NOW see you have done all this. Did you loosen your 4 drive shaft bolts before re-installing your wheel and tire? Install with the correct driveshaft/axlenut torqueing sequence?
« Last Edit: June 15, 2011, 05:18:27 AM by Tundra » Logged
RainMaker
Arlington, TX
« Reply #12 on: June 15, 2011, 07:05:27 AM »
I put on an Altimax 205-60-16, not the 50- Typo (big one in this case).
I've had the bolts reversed after the nut cage mods so that wasn't it.  I think Marty may have an idea - that nut welded inside the fender where I put the washer mod in seems to protrude a lot.
Daniel Meyer said to put duct tape on suspected areas and take a short ride to see if the tape gets torn up. That sounds like a good idea.  He also said that bearings could cause the issue.  So I'm going to drop the wheel after the duct tape run, find the rub and do whatever needs to be done, then replace the bearings just to be sure.
MP - a business cards slides between the swingarm and the tire easily.  So that helps to maybe rule that out.  I'll put duct tale on the inside and see if it rubs just to make sure.
Tundra - On the drive shaft bolts, yes.  Daniel really made that clear as something that must be done when he gave the DFW group a tech session on rear drive maintenance.
I am hoping the rubbing of the tire is what is causing the tire, wheel, pumpkin and swingarm to feel hot.  I will ride my tourer the same route and see if the heat is comparable - I may just be jittery because of the rubbing.
Thanks to all for the ideas.  I had one more idea - has anyone ever put a washer between the pumpkin and the swingarm?  Not sure what a great idea it would be, just wondering.
RM
2005 BMW R1200 GS
1972 CB500K1
lucky_1_chris
Arlington, TX
« Reply #13 on: June 15, 2011, 08:16:02 AM »
Fred.
select specs Smiley
I don't know why their site would give different widths, but Gordon is correct. The 2nd number is the height of the sidewall relative to the width of the tire.
1999 Valkyrie Interstate
Daniel Meyer
The State of confusion.
« Reply #14 on: June 15, 2011, 09:08:11 AM »
Bearings would be the issue if the rub is intermittent. As in, NOT hitting the swing arm at rest, but IS when riding...find the rub spot first, then you'll know more on how to proceed. Replacing bearings that are not bad is a waste of time.
Expect the wheel/tire/swingarm to be ambient + as much as 65 degrees. I would expect them to be hot enough to be uncomfortable to touch in our summer conditions. The pumpkin can get hot enough to burn your hand, even with nice clean synthetic lube in it.
101 yesterday, concrete driveway was 135 degrees via infrared thermometer. Rear tire on arrival home was 160ish. Pumpkin I didn't measure, but I would expect hotter than that. Definitely hot enough to burn.
Don't sweat it so much. Find the rub, then deal with the problem there.
« Last Edit: June 15, 2011, 09:10:13 AM by Daniel Meyer » Logged
CUAgain,
Daniel Meyer
Valkpilot
What does the data say?
Corinth, Texas
« Reply #15 on: June 15, 2011, 10:20:20 AM »
Fred.
select specs Smiley
The different widths are because "section width" includes either one or both sidewall thicknesses, depending on the site giving the definition.  But a 205 has a tread width of 205 mm regardless of sidewall height (within manufacturing variation.)
Back in olden times when I got my first car, a 50 series tire was wider than a 60 series tire, etc., as was referred to.  Those designations have been replaced by the current width in mm/sidewall height as a % of width/rim diameter in inches labeling.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
X Ring
« Reply #16 on: June 15, 2011, 11:05:57 AM »
Something EVERYONE needs to remember is there is NO standardization in tire measurements.  If there was 205mm section width would be the same on every tire with that designation.  When I was looking at specs last night, a 205/65R16 had a section width of 8.2" while a 205/50R16 had a section width of 8.4"!  If you convert 205mm to english measurements it is 8.07".   You need to look at the manufacturers' or distributors' websites cause it seems tire manufactures are like women's clothing manufacturers.  Each has their own standard and it seems to change between sizes in the same model much less different models.
Marty
« Last Edit: June 15, 2011, 07:40:42 PM by X Ring » Logged
Valkpilot
Corinth, Texas
« Reply #17 on: June 15, 2011, 12:58:39 PM »
Something EVERYONE needs to remember is there is NO standardization is tire measurements.  If there was 205mm section width would be the same on every tire with that designation.  When I was looking at specs last night, a 205/65R16 had a section width of 8.2" while a 205/50R16 had a section width of 8.4"!  If you convert 205mm to english measurements it is 8.07".   You need to look at the manufacturers' or distributors' websites cause it seems tire manufactures are like women's clothing manufacturers.  Each has their own standard and it seems to change between sizes in the same model much less different models.
Marty
Marty, you're right, not every 205 is exactly 205 mm wide but it does not mean that a 205/50 is substantially wider than a 205/60 as used to be the case with tire designations when you would say, "Man, that Roadrunner looks boss with those 60 rears and 70 fronts."  cooldude
For one thing, section width is not tread width.  Section width includes one or both sidewall thicknesses, depending on the site you reference for a definition.  I would expect differences in section width as sidewall height changes due to changing structural (stiffness) needs of the sidewall.
To further complicate it, 205 mm is a 'nominal' number subject to manufacturing tolerances.
Unfortunately for us, variations in the Valk frame, fender, and swingarm manufacturing mean that we sometimes find that variations in tire manufacturing produce unexpected results -- the tire rubs.  Wink
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
X Ring
« Reply #18 on: June 15, 2011, 01:25:55 PM »
I have a theory about that.  When I installed a 205/65HR16 Toyo Proxes on my '97 Tourer back in '09, there were some who were stunned that I could fit an 8mm allen wrench between the sidewall and driveshaft tube when they could barely get a credit card or a couple of business cards in theirs.  I believe when the Valk swingarms were being welded together the first year or two the welders were pretty meticulous using the jigs; however, as time went on they didn't pay quite so much attention to the jigs.  The swingarms were in acceptable manufacturing tolerances though.  Couple that with the tire variances and you have a nice set up for clearance issues.
It looks like I may have struck it lucky again.  I installed a Falken 512 205/60HR-16 on my I/S and while I haven't measured it, it looks like I have the same amount of clearance on it.
Marty
Paxton
So Cal
« Reply #19 on: June 15, 2011, 03:00:08 PM »
My Valk is lowered 1-1/2 inches in the rear. It is set up as a "Solo Ride."  coolsmiley
I chose the least expensive CT I could find ($89). It is a NEXEN 205/65/16. Am very happy w/-it...
It has an acceptable lookin' thread too.
CT INSTALLATION:
After the nut cage mod and reassembly, the tire spinned  freely while jacked up. Once on the ground
with the bike's weight, it would rub on the right side bolt.  Angry
We sliced 'bout 1/4" off the bolt. We also sliced the nut in half (ouch!)  Undecided. Problem solved.  Cheesy
When I did the swap, I had gone just 350 miles since purchase... mostly on open highways...
Therefore, I can't speak of the differences in handling characteristics...
I just know that I ain't going back to an M/C tire.  angel
"Everything we hear is an opinion, not a fact. Everything we see is a perspective, not the truth."
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
X Ring
« Reply #20 on: June 15, 2011, 04:48:36 PM »
CT INSTALLATION:
Next time you need to take the wheel out, like say in 10K miles for final drive maintenance, you can do a couple of things.  You can install a carriage bolt inside out with the head on the inside of the fender.  I put a piece of all thread with a nylock nut on the inside of the fender with an acorn nut on the exterior.
Marty
FryeVRCCDS0067
Brazil, IN
« Reply #21 on: June 15, 2011, 06:40:37 PM »
I'm running the same V rated tire at 38-40psi. I also ran a GY TT previously. No problems with either tire.
bscrive
Ottawa, Ontario
« Reply #22 on: June 15, 2011, 07:19:31 PM »
Can you not just go to a 195/60/16 or 195/65/16.  The smaller width would give you the extra clearance I would think.  Can you not get a good quality tire in that size?  I have been considering going to a car tire since I haul a trailer a lot.
Tropic traveler
Silver Springs, Florida
« Reply #23 on: June 15, 2011, 07:32:18 PM »
Been wishing for a tire like that for a while! What I really want is a 195/70/16 or a 185/70/16 car tire but I haven't found one yet.  Undecided
'13 F6B red for Kim
Paxton
So Cal
« Reply #24 on: June 16, 2011, 01:45:41 AM »
To find any tire size which you want to see and touch, go to the most popular tire shop near you.
If they don't have it in stock, they'll order it for you.
Ask to see "the same tire" even though it might be a different size.
If not available, reserve the option of declining purchase if you don't like what you get.
As it turned out I am very happy w/what I got for $89.  Smiley
J. Paxton Gomez
So Cal... 91205
RainMaker
Arlington, TX
« Reply #25 on: June 16, 2011, 07:07:25 AM »
Thank you - that's good to know.
Re-teardown in progress.
2005 BMW R1200 GS
1972 CB500K1
BigM
« Reply #26 on: June 16, 2011, 01:15:52 PM »
Sounds like you may also not be tightening the four drive shaft tube bolts last. throwing it off center.
RainMaker
Arlington, TX
« Reply #27 on: June 16, 2011, 01:26:38 PM »
Actually did but that isn't the rubbing problem.  It's that bolt Marty mentioned.  Gonna' grind it down and do a reverse with an acorn nut on the outside.
Thanks for the idea, though.
2005 BMW R1200 GS
1972 CB500K1
X Ring
« Reply #28 on: June 17, 2011, 08:29:25 AM »
Kinda hard to do that.  That nut is welded to the inside of the frame.  Just grind it down till you get to the end of the bolt.  You should be below the frame then.
Marty
RainMaker
Arlington, TX
« Reply #29 on: June 17, 2011, 08:41:31 AM »
Marty
Wow - hard to believe.  That things sticks out a good 3/4 of an inch from the frame.  I'll take before and after pictures.  But won't get to it for a week or so.
Thanks again.
Mark
2005 BMW R1200 GS
1972 CB500K1
RainMaker
Arlington, TX
« Reply #30 on: June 27, 2011, 01:35:18 PM »
All grinding completed.  Dropped the wheel and rechecked the bearings - think the left may be failing due to the fact that if I put pressure with my thumb on the inner race, it doesn't spin smoothly.
Tripled the washers on the washer mod as well.  Between the extra grinding and the triple washers, no more rubbing.  Bearings on order and will replace them sometime in the next few days.
Thanks for all the help!
RM
2005 BMW R1200 GS
1972 CB500K1
keepinon
New Caney, Tx
« Reply #31 on: June 27, 2011, 09:50:39 PM »
I had purchased a Bridgestone Turanza 195/60 for my 'Wing just a few days before I bought the Valk, so it was not installed before I sold that bike. Fast forward nearly a year, seeing that tire sit in the shop, I decided to try it on the Valk. 1000 miles later, I love it. Not as much "push" as my buddies 205/55, but definitly much better braking and wet road handling (well, in the one day of rain we had here). It is a very "sticky" tire, wear rating of 300.  Bought it at a local Firestone store.
I did the nut cage mod, fender was center, but could have done without, it fit easily. Speedometer seems to read much the same (w/ tach) as before. Surely, it'll get more than the 10k miles I usually get from Metzlers.
1998 GL1500 CT Trike
X Ring
« Reply #32 on: June 27, 2011, 10:23:40 PM »
Valkyrie speedometers operate off the front wheel not the back or tranny so your speedo reading would be unaffected.
Marty
keepinon
New Caney, Tx
« Reply #33 on: June 28, 2011, 06:32:57 AM »
Correct, however, a significantly undersized rear tire would require more engine rpm to attain the same speed. I didn't experience greater rpm's and my fuel mileage has remained the same. Two of the more prevalent concerns I've seen here.
X Ring
« Reply #34 on: June 28, 2011, 08:19:29 AM »
You wouldn't have seen a significant rpm increase as the tire size you chose has an overall diameter of 25.3".  The 205/55R-16 has a diameter of 25" and the 205/60R-16 has a diameter of 25.7".  The 60 series tires are the closest to the stock M/C tire diameter.  The 55 and 65 series show and increase/decrease of approximately 250-300 rpms respectively.
Something everyone considering to go DarkSide needs to remember is when you do your research for a tire, you need to look at the spec sheet.  Not just the size but to make sure it fits on the rim width and the diameter of the tire.
Marty
