August 23, 2025, 04:09:47 PM *
Author Topic: What's the best anti-squeal solution for brakes?  (Read 3467 times)
doubletee
VRCC # 22269
Fort Wayne, IN
« on: June 16, 2011, 12:49:30 PM »
Replaced the rear pads and used a spray-on anti-squeal product. Getting a squeal at very low speeds in the final few feet when coming to a stop. Either I didn't coat the back of the pads heavily enough, or the product simply sux. (BTW - OEM pads on OEM rotor)
Any suggestions for a different product, or just recoat with what I've got?
Brad
Reno, Nevada
« Reply #1 on: June 16, 2011, 12:56:49 PM »
You may have a contaminant on the surface of the pad.  Remove the pads and work the braking surface over with some emery cloth, reinstall and give it a go.
« Reply #2 on: June 16, 2011, 12:59:09 PM »
Some people buy the IS rear pads for their tourer or standard because they a a couple bucks cheaper, but the standard pads have an anti squeal pad......I agree with above....clean all that junk off and make sure you have the right parts
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #3 on: June 16, 2011, 01:15:34 PM »
I bought the pads for a std, not the IS pads. I'm assuming the anti squeal pad to which you refer is the thin aluminum (looking - don't really know it's composition) plate on the back of the pad. My new ones came with those.
Thanks to both responses. I'll remove, clean the surfaces and reinstall.
« Reply #4 on: June 16, 2011, 05:31:52 PM »
Should also be a white soft padding underneath that thin metal...between it and the back of the pad. I always use some of the Anit Sqeal red goop, I don't use the spray on. Stuff I use comes in a plastic squeeze bottle, used it on cars and bikes for years.
« Reply #5 on: June 16, 2011, 05:44:44 PM »
WD 40 stops squeeks.
Quicksilver
Norway Bay, Quebec, Canada
« Reply #6 on: June 16, 2011, 06:17:00 PM »
+1 Wd 40
1997  Standard
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #7 on: June 16, 2011, 08:59:43 PM »
i use the anti-squeel stuff on my cars, and trucks, but i use nothing oin my motorcycle brake pads....just keep the pads and the rotors clean with q-d electronic cleaner......no squeaks.
