March 24, 2026, 10:41:54 AM *
Author Topic: NEW BATTERY  (Read 1902 times)
BIG--T
The Twilight Zone
« on: June 16, 2011, 08:22:50 PM »
Do anyone know any good websites with a good price on batteries? I googled YTX14-BS and about all are over $100!
Thanks for any help
« Reply #1 on: June 16, 2011, 08:32:27 PM »
Thanks for any help
Think I gave about $80.00 for mine three years ago from the local Honda shop .I replaced it at 10 years old it's in my 450 Foreman 4 wheeler now. Got a buddy who wanted to save a few buck$ went with whatever brand Wally World sells it lasted 2 years .
F6Dave
« Reply #2 on: June 16, 2011, 08:46:23 PM »
I'm not sure why, but if you order a battery from the OEM parts section of some websites, it costs somewhat less.
Thunderbolt
Worthington Springs FL.
« Reply #3 on: June 17, 2011, 02:53:46 AM »
I think this is where I bought my last one.  Free shipping and no tax.  Came in the mail in like 3 days across the country.  It's a Yuasa, like OEM.
http://www.batterystuff.com/powersports-batteries/YTX14-BS.html
alph
Eau Claire, WI.
« Reply #4 on: June 17, 2011, 03:16:37 AM »
that's the same website i bought my battery from.  it replaced my original battery that came with the cycle!! i made sure that the battery was made in USA, call me what ever you want, but i'm pretty sure that the quallity control department in chineese companies could care less if they're filling up our landfills with crap.
STAY AWAY FROM THE WALLYWORLD CRAP!!  YOU'LL BE WAISTING YOUR MONEY!!!
BIG--T
The Twilight Zone
« Reply #5 on: June 17, 2011, 05:27:58 AM »
-Thanks guys for the help- Yeah I won't buy a battery at wallyworld! cooldude
Gary
Northern New Mexico
« Reply #6 on: June 17, 2011, 05:40:58 AM »
Ditto on the Battery Stuff outfit. I think I ordered mine late one Friday night and it was on my doorstep that Monday. $84.00 (?) couple months ago. Shipping priority mail included at that price.
2 different sales transactions over the years (2 bikes), same great service.  Wink
« Reply #7 on: June 17, 2011, 05:51:42 AM »
Batteries Plus is a good source:
http://www.batteriesplus.com/products/558-CC/4419-Motorcycle-Batteries/136647-Honda/GL-Valkyrie/1500CC-1997-to-2003/1.aspx
They have an AGM for $85
My Valk currently has a Wally World AGM, it has been in for about a year with no issues.
It wasn't my first choice but when the old battery died I needed a new one fast and Wally World was convenient.
Most motorcycle batteries are made by YUASA, and they seem to be the same no matter whose label is on the outside.
My next battery will be one of the sealed Gel batteries they are susposed to be far superior to the lead acid or AGM batteries.
Here's one on E-Bay made by YUASA for $57 + $13 (shipping):
http://cgi.ebay.com/ebaymotors/YUASA-GEL-BATTERY-YTX14-BS-BMW-Ducati-Triumph-Yamaha_W0QQcmdZViewItemQQcategoryZ35594QQitemZ170366258115
PAVALKER
Pittsburgh, Pa
« Reply #8 on: June 17, 2011, 06:23:52 AM »
Very interesting......
 at DLP that battery is 79.95
http://www.directlineparts.com/product.asp?pid=501&str=2
And.... at their OEM parts section iit is 66.27
BATTERY (YTX14-BS)
31500-HC4-726AH  (replaces 31500-HA7-676)    001    $80.02    $66.27
« Last Edit: June 17, 2011, 06:25:30 AM by PAVALKER » Logged
John
« Reply #9 on: June 17, 2011, 06:54:41 AM »
found this:
GEL vs. AGM Sealed Batteries
Motorcycle Batteries All Batteries Battery Chargers 6–48 Volts Solar Chargers Pure Sine Inverters Battery Restoration Battery Products Fuel Treatments Engine Cooling NiMH Rechargeables Power Tools Emergency AGM (absorbed glass mat) is a special design glass mat designed to wick the battery electrolyte between the battery plates. AGM batteries contain only enough liquid to keep the mat wet with the electrolyte and if the battery is broken no free liquid is available to leak out.
Gel Cell batteries contain a silica type gel that the battery electrolyte is suspended in, this thick paste like material allows electrons to flow between plates but will not leak from the battery if the case is broken.
More often than not AGM Batteries are mistakenly identified as Gel Cell Batteries. Both batteries have similar traits; such as being non spillable, deep cycle, may be mounted in any position, low self discharge, safe for use in limited ventilation areas, and may be transported via Air or Ground safely without special handling.
AGM Batteries outsell Gel Cell by at least a 100 to 1. AGM is preferred when a high burst of amps may be required. In most cases recharge can be accomplished by using a good quality standard battery charger or engine alternator. The life expectancy; measured as cycle life or years remains excellent in most AGM batteries if the batteries are not discharged more than 60% between recharge. There are some AGM batteries we sell that offer excellent 80%+ deep cycle abilities.
Gel Cell Batteries are typically a bit more costly and do not offer the same power capacity as do the same physical size AGM battery. The Gel Cell excels in slow discharge rates and slightly higher ambient operating temperatures. One big issue with Gel Batteries that must be addressing is the CHARGE PROFILE. Gel Cell Batteries must be recharged correctly or the battery will suffer premature failure. The battery charger being used to recharge the battery(s) must be designed or adjustable for Gel Cell Batteries. If you are using an alternator to recharge a true Gel Cell a special regulator must be installed.
This is from the following website:
http://www.batterystuff.com/tutorial_battery_gel_agm.html
I had noted that "TRUE" Gel Cell batteries were harder to find than AGM batteries.
Going by this it would seem that a sealed AGM is a better choice than a Gel Cell.
Their website has 3 choices from $61-$89 with FREE Shipping:
http://www.batterystuff.com/batteries/motorcycle/honda/1999/1500cc-gl1500-valkyrie/
Two of them are made in the USA by Yuasa
« Last Edit: June 17, 2011, 07:17:36 AM by 3fan4life » Logged
vanagon40
Greenwood, IN
« Reply #10 on: June 17, 2011, 06:56:34 AM »
Just purchased a YTX14H-BS from J R Graham Powersports.  $78.16 total to my door.  Fast shipping.
http://www.jrgraham.com/itemdetail.do?action=prepare_detail&itm_id=163272
Not affiliated in any way, just a satisfied customer.
« Reply #11 on: June 17, 2011, 07:04:30 AM »
For $80 you can get it with the acid already in it, fully charged and ready to go:
http://www.jrgraham.com/simplesearch.do?action=process_simple_search&searchType=S&simpleSearchType=D&keyword=920-134
It doesn't say that it is an AGM battery. I believe that I would ask for clarification on that before I bought one.
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #12 on: June 17, 2011, 07:07:01 AM »
Most dealers buy there batterys from Interstate because they sell the yussa batterys. I buy wholesale at interstate and I usually pay 60.00 for a YTX14-BS  However they make a YTX14H-BS that has 240 cold cranking amps for 79.00
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #13 on: June 17, 2011, 07:42:59 AM »
Just purchased an OEM from the dealer for $80. They add the acid and give it the proper initial charge so it's ready to go.
Mr. Nuts
Bitterroot Valley Montana
« Reply #14 on: June 17, 2011, 08:00:27 AM »
I have had good service from Tri State Batteries and the Valk battery is cheap there too.
http://www.tristatebattery.com/product_info.php?products_id=732
Motocross brand by Yuasa is $59.95 shipping included.
This is one where you add the acid and do the initial charge yourself. It's easy to do and the instructions are good. You do need a charger though. I prefer this method so I can be guaranteed the battery is freshly charged, and that the initial charge is properly done.
“Speed has never killed anyone.... Suddenly becoming stationary, thats what gets you.” - Jeremy Clarkson
BIG--T
The Twilight Zone
« Reply #15 on: June 17, 2011, 01:02:41 PM »
Thanks for all the help but there is a guy called the Battery Geek and has a AGM Gel for $31.63. Has anyone ever done business with him? Sounds too good to be true...with a year warranty. All the battery + and similar are $79 and up!
Let me know about the Geek
Thunderbolt
« Reply #16 on: June 17, 2011, 04:22:27 PM »
it probably is..............
