March 24, 2026, 10:42:47 AM *
Author Topic: chrome side covers... triple plated vs vacuum metalization  (Read 1382 times)
designer
Columbus, Ohio
« on: June 17, 2011, 08:20:16 AM »
OK, I don't know if anyone would know this, but is the side covers that were offered by Hondaline chrome plated or vacuum metalized?  It seems to me if the sell prices was below $100 from the OEM they would have to be vacuum  metalized.  Does anyone have a set and if they do what is the quality of the chrome?
2002 Valkyrie Std
K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
Ferris Leets
Catskill Mountains, N.Y.
« Reply #1 on: June 17, 2011, 08:30:52 AM »
Fairly certain that you can not plate (chrome)  plastic.
« Reply #2 on: June 17, 2011, 08:33:04 AM »
I think Big Mike bought up some side covers and chrome plated them... maybe he can
specify what the exact process really is...
designer
Columbus, Ohio
« Reply #3 on: June 17, 2011, 08:35:00 AM »
ABS and PCS+ABS can be chrome plated with no problem.  It takes a specific grade of ABS to plate.  I've been chrome plating plastic parts and vacuum metalizing them for over 30 years.  Stated the the '87 Lincoln making some vacuum metalized chrome parts.  I'm really interested in which method Honda used.  triple chrome plating is about $300 for the side covers, but vacuum metalization is only about $100 for the covers.
2002 Valkyrie Std
designer
Columbus, Ohio
« Reply #4 on: June 17, 2011, 08:38:28 AM »
just sent him an email, forgot all about his parts.
2002 Valkyrie Std
Ferris Leets
« Reply #5 on: June 17, 2011, 12:23:12 PM »
I am surprised that the plastic would conduct enough electricty for plating.
Bobbo
Saint Charles, MO
« Reply #6 on: June 17, 2011, 12:58:56 PM »
In VM plating, no electroplating is used.  The host metal is vaporized in a vacuum and it deposits on the plastic in a very thin layer.  If you VM plate plastic with copper, you then have a conducting surface to plate with nickel, and finally chrome, for traditional triple chrome plating.
Ferris Leets
« Reply #7 on: June 17, 2011, 01:26:29 PM »
New knowledge.  Thanks.
FryeVRCCDS0067
Brazil, IN
« Reply #8 on: June 17, 2011, 05:22:50 PM »
New knowledge for me too. Thanks for sharing it.
designer
Columbus, Ohio
« Reply #9 on: June 17, 2011, 06:41:22 PM »
Your spot on bobbo, the vm is not as good as triple plating. It can peel easy if not prep'd right.  But after talking to Mike I think I'm going to have mine done. Place in california.
2002 Valkyrie Std
