February 02, 2026, 06:17:32 PM
97 Running way too lean
Topic: 97 Running way too lean (Read 1708 times)
freud1au
June 17, 2011, 05:35:14 PM »
Was running a bit lean before I fitted cobra six into six pipes.
Gave it a quick Dino after because she would not run under load above 2000rpm.
Ran fine under 2k at 12ppm but above 2k was 18ppm.
I ordered and fitted the cobra jet kit. Came only with needeles springs etc but no jets.
Re dyno and now at 16ppm. When I spoke to the dyno guy he told me that normally the kit comes with a drill to drill out to aloe the diaphragms to lift earlier in rpm.
Does anyone know what the size of the drill is and what size jets I should be running?
I turned my plugs white in under 50 miles
designer
Columbus, Ohio
Re: 97 Running way too lean
June 17, 2011, 07:15:23 PM »
Got a pic of plugs. My plugs are always white and it's only has K&N with pre-filter. No other running mod.
2002 Valkyrie Std
K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
wizard -vrccds#125
Hitchcock Tx.
June 17, 2011, 07:35:34 PM »
I am running 112.5 main jets with the C-clips one from the top. 6 deg trigger wheel and I/S ECM. Twist it at 5MPH and it will light up a 205 CT. Main jets I got at the local H-D dealer (thy said thy would work ) but what do thy know
freud1au
June 17, 2011, 07:45:48 PM »
Wiz did you drill the vacuume for the slides? If so what size.
No photo of the plugs. By white I mean from shiny silver new plugs to paper white in less than half a tank
designer
Columbus, Ohio
June 18, 2011, 06:20:49 AM »
Yeah, little lean.
2002 Valkyrie Std
wizard -vrccds#125
Hitchcock Tx.
June 18, 2011, 07:01:53 AM »
Did not need to drill anything ! Just a good cleaning !
freud1au
Reply #6 on:
June 21, 2011, 09:27:39 PM »
Ok I will make a set of 112.5 jets. See how we go from there.
Where did you get the six deg from
freud1au
Reply #7 on:
June 22, 2011, 03:08:43 AM »
Ok 112.5 still too small
Ended up 117's
Duck me I thought she went before but now. Wow
Thanks wiz for the info to start me off
wizard -vrccds#125
Hitchcock Tx.
Reply #8 on:
June 22, 2011, 01:46:51 PM »
You are welcome !
I am still tinkering with the other one and almost got it !
