November 23, 2025, 06:47:09 AM
Cruise control,
Topic: Cruise control, (Read 1359 times)
Ghost Rider 2
Downs, Illinois
Cruise control,
June 18, 2011, 03:58:00 AM »
Looking for imput on a cruise control. Rostra electronic or the audiovox vacumm system. My thoughts are with no vacumm container it would be easier to hide everything.
NITRO
Eau Claire, WI
Re: Cruise control,
June 18, 2011, 05:55:41 AM »
I just installed the audiovox vacumm unit without a vacumm canister, as have many others. You just tap into two of the intake tubes. It works exactly as it should!
http://www.murphskits.com/catalog/product_info.php?cPath=25&products_id=422
Last Edit: June 18, 2011, 05:58:44 AM by NITRO
When in doubt, ride.
Mr. Nuts
Bitterroot Valley Montana
Re: Cruise control,
June 18, 2011, 06:16:54 AM »
My audiovox works great without a cannister. I hooked into all six with vac lines. Don't know if I needed all 6, but they were there, and they weren't doing anything else, so I figured why not. Lots of mountains in Montana but I haven't had a problem. Biggest chore was finding enough check valves. Each auto store either only carried one or two so I had to make quite a few stops.
Don't know anything about the other brand but I'm guessing lots more help is available here for the audiovox since so many of us have them.
“Speed has never killed anyone.... Suddenly becoming stationary, thats what gets you.” - Jeremy Clarkson
designer
Columbus, Ohio
Re: Cruise control,
June 18, 2011, 11:49:55 AM »
Never could get mine to work without canister. Even tried three vacuum lines together. Small can and it worker.
2002 Valkyrie Std
K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
=> InZane XXV
