November 23, 2025, 06:47:08 AM *
Author Topic: Carb question  (Read 1300 times)
Al in Arkansas
Pea Ridge, Arkansas
« on: June 18, 2011, 07:27:28 AM »
Working on rebuilding carbs.  Taking my first one apart for cleaning and found that this brass nipple (I'm sure there's a proper name...) under the air-cut off valve seems loose.  I would have expected it to be solid, but it wiggles.  When I take my next carb apart I'll know if it's the same, but I wondered if anyone could tell me if this is normal?  Thanks - Al
Thanks - Al
Al in Arkansas
Pea Ridge, Arkansas
« Reply #1 on: June 18, 2011, 07:46:27 AM »
Ok, should have looked a bit more before asking Smiley.  It is simply held in the hole by an o-ring.  Comes right out.
I'm sure I'll be back with a real question later in this process...  Thanks - Al
fordmano
San Jose, CA.
« Reply #2 on: June 18, 2011, 10:49:28 PM »
Yep take your time you will catch on,,,, I did. Took me a while but I am a SLOW learner most of the time...
Be real CAREFUL with them aircut valves they is MIGHTY PRICEY from Honda, from memory better part of $40 each. Shocked
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
