February 02, 2026, 06:17:18 PM *
Author Topic: Need help on how to remove sticky tape/label stiker...  (Read 1856 times)
Peter55
Fairfax VA
« on: June 18, 2011, 05:18:56 PM »
Hi guys, not sure this is the right forum for the question so sorry if it isn't.
Can anyone suggest how to remove a stiker ( which has been there few years ) from the front forks?
It doesn't seem to peel off and i don't want to scrape it off either. Is there any chemical I could use to remove it without damaging the fork's metal?
Thank you in davance for any suggestion.
Farther
Quimper Peninsula, WA
« Reply #1 on: June 18, 2011, 05:26:43 PM »
Auto parts store carry several product, such as Goo Be Gone, that will take the sticker off with some patients.  None of them work as good as advertized.  One product comes with a plastic scraper that, hopefully, won't damage the finish.
~Farther
Grandpot
Fort Mill, South Carolina
« Reply #2 on: June 18, 2011, 05:31:47 PM »
Use a hair dryer to soften the adhesive and peel off the sticker. Use charcoal lighter fluid to clean off the remaining adhesive.
X Ring
VRCC #27389, VRCCDS #204
« Reply #3 on: June 18, 2011, 06:07:57 PM »
WD-40 is good for softening adhesive.
Marty
YoungPUP
Valparaiso, In
« Reply #4 on: June 18, 2011, 06:53:06 PM »
3M General Purpose Adhesive Cleaner  P/n 08984. Check with carquest or local body supply store. Put it on a rag and leave it sit on the problem, them scrape with soft object. (kept my expired drivers license for this job) It DOES remove wax/ etc, so rewax when finished. Also removes pinstriping (hand painted, and the cheap roll type crap). May take an application or 2 but this is a detail shop level product, so have faith in it. Works GREAT for taking old stickers off of glass as well, just use a good foaming type glass cleaner when you're done as it leaves a light residue. As a valuable side note it also takes the expanding foam insulation ( for filling cracks aorund windows etc. ) off of your hands tools etc, if used before it dries....
99 STD (Under construction)
« Reply #5 on: June 18, 2011, 07:03:43 PM »
nothing works better than Ronsinol lighter fluid....like what you fill a zippo with
designer
Columbus, Ohio
« Reply #6 on: June 18, 2011, 07:06:16 PM »
90 percent rubbing alcohol and elbow grease.
2002 Valkyrie Std
K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
Paxton
So Cal
« Reply #7 on: June 18, 2011, 08:48:59 PM »
 Cheesy Cheesy ACETONE  Cheesy Cheesy
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
« Reply #8 on: June 19, 2011, 02:55:29 PM »
rubbing alcohol and working hard is a great recipie for scratches
Peter55
Fairfax VA
« Reply #9 on: June 19, 2011, 05:56:33 PM »
Thank you all guys. I now I have several option to try out. I appreciate your suggestions.
