February 02, 2026, 07:52:14 PM *
Author Topic: Finally got around to putting some paint on the Valkyrie's trunk.  (Read 2675 times)
bigguy
VRCC# 30728
Texarkana, TX
« on: June 19, 2011, 07:26:37 PM »
I finally got around to putting some paint on my trunk.
click thumbnail for larger image in a new window.
Here there be Dragons.
« Reply #1 on: June 19, 2011, 07:49:34 PM »
I like the way you did the pictures  cooldude How do you do that ?   Is the passenger backrest not removeable ?
bigguy
VRCC# 30728
Texarkana, TX
« Reply #2 on: June 20, 2011, 07:10:25 AM »
Two screws from the inside of the trunk lid.
bigguy
VRCC# 30728
Texarkana, TX
« Reply #3 on: June 20, 2011, 07:14:36 AM »
Thanks. I have a photo gallery on my personal website that generates a thumbnail and two sizes of photo. I just use BB code to define a table and put a linked image of the thumbnail to the gallery page with the photo.
If you hit the"quote" button on my post, you will be able to see the code.
bigguy
VRCC# 30728
Texarkana, TX
« Reply #4 on: June 27, 2011, 06:46:29 AM »
Got better paint and did a better job.
click thumbnails for larger image in a new window.
X Ring
VRCC #27389, VRCCDS #204
« Reply #5 on: June 27, 2011, 07:34:25 AM »
Pretty close.  Only problem is it looks a lot newer.  Go figure!  You could have gotten a rattle can of of the stock paint color from Colorite.
Marty
bigguy
VRCC# 30728
Texarkana, TX
« Reply #6 on: June 27, 2011, 08:03:58 AM »
Marty
Yeah. It was $39.95. I got close enough I can't tell the diff for about $17.00. If I decide I don't like this, I can always pop for the can from Colorite. That was my original plan, but I'm such a cheap @$$, that I'll give this a try first.
Ha! and you're right about it looking newer. There's some sort of film all over the bike. I discovered that when cleaning off a spot to color match. That explains most of the color diff you see in the photos. Gently buffing with a little Plastix takes it off. Just got to get off my lazy butt and do it.
« Last Edit: June 27, 2011, 08:06:52 AM by bigguy » Logged
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« Reply #7 on: June 28, 2011, 01:00:50 AM »
I like it better than the first pics. The first ones seemed to be flat, was that by design? Or just the paint, or not sanded/buffed out yet? Either way, I like it! Looks like it was MEANT to be...
I'm getting ready to do my saddlebags, I have single stage paint, figure it will be fine, instead of base/clear. Mainly because I can't decide which way to paint them, and it will cost a lot less, to paint them twice in single stage, than once in b/c. I have a rather big shop, that I can set up a pretty dust-free paint booth, at least big enough for the bags, and can hopefully do a nice enough job, that it won't look TOO amateurish.
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
bigguy
VRCC# 30728
Texarkana, TX
« Reply #8 on: June 28, 2011, 04:44:36 PM »
It wasn't meant to be flat. The only paint I cold find at Lowe's in the color I wanted was in a flat finish. I had hoped that a coat of clear would gloss up the finish. Additionally, I didn't do a very good job of surface prep with no sanding between coast.
I smoothed it down real good this time before I started, then wet sanded with 300 grit between coats.
Up close and in person, you can still see a little texture on the finish. But you've got to be looking for it. I think it's as good as you're going to get from a rattle can, out in the open air. A pro wouldn't be impressed, but I think I got my $20 worth.
Jess Tolbirt
White Bluff, Tn.
« Reply #9 on: June 28, 2011, 07:59:02 PM »
I cant remember the name of the color on the can,,but i found an exact color match of that red at auto zone and wal mart in the dupli color brand,,used it on my 98's saddle bag
Valkyrie member # 23084
« Reply #10 on: June 28, 2011, 08:10:03 PM »
IMO it looks much better with the black scallop on the saddlebags it follow's the lines of the tank much better.
Walküre
Oxford, Indiana
« Reply #11 on: June 28, 2011, 09:12:35 PM »
didn't mean to hijack, but yeah, general consensus is to match the tank. I'll probably start with that, and hopefully be done with it.
Roger Phillips
Oxford, IN
VRCC #31978
bigguy
VRCC# 30728
Texarkana, TX
« Reply #12 on: June 29, 2011, 06:29:59 AM »
I agree with you and Walküre.
