February 06, 2026, 04:19:12 AM *
Author Topic: Polishing float valve seats  (Read 7619 times)
F6AJ
Mobile,Alabama
« on: June 20, 2011, 09:01:21 PM »
I will be polishing the float valve seats this week (38 & 105 jets and float valves all new).....Been told " I use 1000 grit paper or wooden stick Q tips with compound".
My question if I polish with compound, what "compound"  is best ?
Thank you
AJ
Ferris Leets
Catskill Mountains, N.Y.
« Reply #1 on: June 21, 2011, 05:43:13 AM »
CLOVER brand polishing compund, comes in 440, 600, and 1200 grit.  Those are the ones I know of.  1200 is almost mirror finish on steel.
« Reply #2 on: June 21, 2011, 07:24:38 AM »
What is it that you expect to gain from polishing the float valve seats?
« Reply #3 on: June 21, 2011, 07:25:39 AM »
I think u will have nothing but problems doing that. And I believe that they are not replaceable except getting a whole new carb body.  The seats have a particular taper and finish, which u will not be able to maintain by hand.
Westsider
Fort Worth TX.
« Reply #4 on: June 21, 2011, 08:14:01 AM »
+1
bigfish_Oh
Allis
West Liberty,Ohio 43357
« Reply #5 on: June 21, 2011, 10:23:48 AM »
+1
+2
maybe clean them with a Q-tip and alcohol, do not let the stem touch them
2012 HD Road King Classic, Teq sunrise/HD Orange
2009 HD Nightster,orange
1974 CB550F,org
1999 Valkyrie,orange/Black (20K)
2009 GMC 3500 Duramax CC Dually 4wd (new)
1957 WD45 Allis Chalmers Grandpa bought new
1982 CBX (new)
1980 CBX (6K)
1979 CB750F (new)
1958 Lambretta TV175 (Dad's new)
4
Pete
« Reply #6 on: June 21, 2011, 01:31:04 PM »
I suspect that you will be ok with 1200 and a very light pressure and short duration.
I am guessing that you are "cleaning" then up, so be careful. Polish not resurface.
If you use a q-tip, wet it and gently form it to the seat before using the compound.
Good luck and be careful.
F6AJ
Mobile,Alabama
« Reply #7 on: June 21, 2011, 08:58:23 PM »
As always I appreciate the input from all you guys.
" What is it that you expect to gain from polishing the float valve seats?" Thanks Rick-D
I was just following the procedure told by the local dealer's Service Mrg.
On second thought,I believe I will just clean them!
AJ
« Reply #8 on: June 22, 2011, 07:23:20 AM »
Float valve needles and seat need no maintenance.
Especially so if you are having no problems.
All it would take is an error to cause problems,
the rubber tips on the needles are delicate!
Clean the float bowls if you feel the need.
Stop listening to that service guy. He's nuts!
Motomonk
Russia
« Reply #9 on: December 07, 2012, 10:42:13 PM »
I installed 6 new needle valve in my carbs, but they still flow! How can I solve this problem? Polished valve seats? Replacement carburetor body? Please, if someone has encountered such a problem - tell me how you removed the leak.
You should not cave in to a changing world, one day he will sag under us.
« Reply #10 on: December 08, 2012, 07:55:28 AM »
Stock or aftermarket needles?
Post some pictures!
All six would indicate a real material part problem.
What all did you do?
« Reply #11 on: December 08, 2012, 02:10:22 PM »
My local service shop polishes the seats with valve lapping compound on a BB. He rolls it around in the seat.
keepinon
New Caney, Tx
« Reply #12 on: December 08, 2012, 06:22:39 PM »
I went thru this a few weeks ago. A 98, been sitting since 2005. Rebuilt carbs, but still had bypass from the float needles. (hydro-lock) I pulled them apart again, used q-tips and spray brake cleaner to remove the laquer build up that soaking in carb cleaner missed. Re-installed, they work as they should.
The laquer buildup from today's fuels is a troublesome thing to remove from small places.
1998 GL1500 CT Trike
Motomonk
Russia
« Reply #13 on: December 08, 2012, 09:44:37 PM »
Many thanks to all who responded. I want to clarify something. Needle valve purchased from Honda. They are the same as they were before the repair. Flow, not all six. Only 3 of them. I'll try to start with brake cleaner to clean the seat. If not help, I'll polish the saddle.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #14 on: December 09, 2012, 05:53:25 AM »
I wouldn't use brake cleaner anyplace it might contact rubber or rubber-like seals or parts.  But I would use spray carb cleaner which may be more effective for localized use than the stuff you put in the tank.  I recently had to dismantle and clean the carb for a pressure washer.  The spray carb cleaner dissolved the gum and laquer from the float seat and jets almost instantly.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #15 on: December 09, 2012, 10:32:37 AM »
I have never removed the carburetors from my Valkyrie so I don't know if the valve seats are threaded in or pressed in. I suspect they are pressed in.
I know this however: That if you modify the valve seats you will necessarily change the gasoline level (float level) in the carburetors which will affect the running of the motor. And it could be worse, possibly!
Polishing the seats (changing the profile) is modifying, anyway you call it, and since the float is non-adjustable you will be shackled with whatever the consequences of doing so, may be.
I consider that most all problems with the float/needle are due to the barrel in which the needle slides up and down. The barrel can become restricted, reducing easy movement of the needle, thereby allowing gas to flow when it should be stopped. It can also do the same in stopping gas from flowing when it should actually be allowing gas to flow.
I feel the most pro-active treatment would be to flush some carburetor cleaner through the carburetor to rid the carburetor of any buildup although I can't recommend to do so because of possible damage to the non-metal components of the carburetor from some of the more powerful agents.
« Reply #16 on: December 10, 2012, 01:07:00 PM »
Thank you
AJ
Good ole Brasso and a Q-tip. Then clean the port with carb cleaner. Don't use sandpaper on that port, could be irreparable damage. FWIW
My rides:
