February 02, 2026, 06:17:33 PM *
Author Topic: Waterproofing Audiovox CC Pad  (Read 1495 times)
NITRO
Eau Claire, WI
« on: June 21, 2011, 07:33:17 PM »
I know that most people have used silicone smeared on their control pads to water proof them, but I just came across these covers that do the same thing without making a mess. This is the same company that is again selling the cruise unit. I just got mine in the mail today and it looks like it'll do the job just fine.
http://www.murphskits.com/catalog/product_info.php?cPath=25&products_id=69
When in doubt, ride.
Daniel Meyer
The State of confusion.
« Reply #1 on: June 22, 2011, 08:14:09 AM »
Pretty cool. Nice that they sell the replacement control pad too...mine's getting a bit long in the tooth after 140,000 miles.
CUAgain,
Daniel Meyer
« Reply #2 on: June 22, 2011, 11:09:44 AM »
Does it slip down over the entire pad and cover the back as well? If not, you're still open to moisture problems. Mine doesn't have that cover so after sealing the inside by separating the two halves and adding some around the area, I then ran a small bead of RTV around the perimeter in back as well as around the cable entry point. I've been in some horrendous storms with no troubles in the six years it has been on there. I also removed the connector that's a couple feet from the control bad and hardwired it together. That's another point of entry for the elements.
NITRO
Eau Claire, WI
« Reply #3 on: June 22, 2011, 12:24:18 PM »
It wraps around and covers most of the back, but you would still want to seal around the wiring as it is exposed.
