February 02, 2026, 06:17:20 PM *
Author Topic: tightened screws  (Read 1428 times)
csj
Peterborough Ontario Canada
« on: June 22, 2011, 09:46:51 AM »
There was a post recently about tightening up the screws on
the intake runners.
I tried it, put screwdriver on and got 2 turns. But the screws
had not worked loose. All six were in their original, 13 yr old positions.
They snapped out of their places, then tightened down.
No discernable change in performance after tighten.
I think the rubber had 'shrunk (aged) down', so, if it shrunk, maybe
the rubber is also lightly perforated. I may have a leak that can
only be fixed by replacing the rubber.
I didn't go tighten the other twelve under the tank. The bike ain't
broke (runs like scalded dog), so not gonna make the full fix now.
Opinions?
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #1 on: June 22, 2011, 10:21:40 AM »
the intake runners.
Opinions?
I'm with you:  If it ain't broke, don't fix it. Ride it like you stole it until a problem really does present itself (Note:  I'm not suggesting one ignore normal routine maintenance)
« Reply #2 on: June 22, 2011, 10:52:04 AM »
I doubt your concern about the quality of the rubber is viable.
The clamps work as designed and there is no need to extrude the rubber by over-tightening the clamp screws, not saying that this is what you have done!
The rubber ends are indexed as well as the clamps themselves which tends to keep everything in correct alignment when adjusting becomes necessary.
