May 02, 2026, 12:12:06 PM *
Author Topic: hooking up mp3 player  (Read 2077 times)
jimnvalk
Four wheels move the body, 2 wheels move the soul
Van, Texas
« on: June 22, 2011, 02:41:37 PM »
ok i am technology challenged when it comes to electronics.  What kind of hook up do i need.  I know that it needs a small male pin for both ends, but evidently they are differenr kinds.  I have one that fits the mp3 player and the aux plug under right side panel, but will not play.  I switched the plugs but still nothing.  Help please
Let the Fun Begin.
99 Valk
98 magna-sold
Jim
MOOT #610
VRCC #30250
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #1 on: June 22, 2011, 03:03:50 PM »
If you are talking about an Interstate this setup will work just switch to AUX. I've done it with two different MP3 players and they both worked great.
jimnvalk
Van, Texas
« Reply #2 on: June 22, 2011, 03:19:22 PM »
I tried that but it would not play.  the ear plugs i have have 2 rings around the plug and it works fine.  The wire i have to try on the valk has one ring on one plug and 3 on the other. Does this make a difference.
Let the Fun Begin.
99 Valk
98 magna-sold
Jim
MOOT #610
VRCC #30250
Houdini
Allen, TX
« Reply #3 on: June 22, 2011, 03:37:11 PM »
Yep.  They have an extension at Radio Shack, I paid about six bucks for mine; it runs under the tank and up to an MP3 holder on the handlebars.  It's a male to male mini RCA jack I believe but ask the experts....
This one is too long but an example of what you need.
http://www.cyberguys.com/product-details/?productid=2735&sk=MC71419&cm_mmc=Google%20Product%20Search-_-Feed-_-CSE-_-Text&utm_source=google-product-search&utm_medium=cse&utm_term=190%2B0347&utm_campaign=product-search
grego
« Reply #4 on: June 22, 2011, 06:27:47 PM »
Yep as said prior you want a stereo plug (2 rings) on either end.
Make sure you are on AUX on I/S audio
Also make sure to turn up the volume      on the MP3 Player
(I set mine at about 90%)
more mp3 volume = louder volume range out of the IS system
and I sometimes forget to hit 'play'    Roll Eyes
and [ahem] sometimes I leave the switch set to helmet/earphones and have to flip it to external speakers when not using the helmet earphones
« Last Edit: June 22, 2011, 06:56:24 PM by grego » Logged
Rockwall, Tx
VRCC # 28263
Rocketman
Seabrook, Texas
« Reply #5 on: June 22, 2011, 07:33:04 PM »
RCA jack is not the correct term.  That will get you a cable like one that you might use to go from your DVD player to your TV.
You want exactly what Houdini linked to (although, as he said, 12 ft. might be overkill).  Male to male, 3.5 mm (AKA 1/8") audio cable.
I'm not sure what you mean by one ring and three rings.  There should be three silver, separated by two black rings.  plug one end into the player, and one into the aux plug under the right side cover.  Verify you've got radio sound, then switch over to AUX.  Hit play on your player, and crank it up (I set it for full volume, personally).  That should do the trick.
jimnvalk
Van, Texas
« Reply #6 on: June 23, 2011, 05:25:49 AM »
Thanks everyone I am on my way to Radio Shack today and get one.  I printed out the info Houdini sent me to take with me.  I attached a pic to show what mine looks like
Let the Fun Begin.
99 Valk
98 magna-sold
Jim
MOOT #610
VRCC #30250
RainMaker
Arlington, TX
« Reply #7 on: June 23, 2011, 06:55:10 AM »
Not sure what that cable in the picture goes to, but it definitely won't work with the MP3/Aux setup.
One warning - the cable Houdini told you to get will work, but your music will play slower since it is a black cable........
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
Houdini
Allen, TX
« Reply #8 on: June 23, 2011, 12:14:20 PM »
My coworkers must think I'm crazy 'cause I truly busted out laughing reading this.  Thanks RM, good one.
jimnvalk
Van, Texas
« Reply #9 on: June 23, 2011, 12:34:35 PM »
got the cable and now just have to run it.  I guess RM i will have to paint it. 2funny
Let the Fun Begin.
99 Valk
98 magna-sold
Jim
MOOT #610
VRCC #30250
jimnvalk
Van, Texas
« Reply #10 on: June 24, 2011, 05:03:18 AM »
Up and running for a $1.  Thanks for all the advice.  Now I can listen to some real motorcycle riding tunes.
Let the Fun Begin.
99 Valk
98 magna-sold
Jim
MOOT #610
VRCC #30250
jimnvalk
Van, Texas
« Reply #11 on: July 16, 2011, 05:50:17 PM »
ok for  problem, when i hook up my player and crank the engine i get spark noise, how do I get rid of that?  Thanks
Let the Fun Begin.
99 Valk
98 magna-sold
Jim
MOOT #610
VRCC #30250
Wanderer
The Great Republic of Texas - Dallas
« Reply #12 on: July 16, 2011, 08:13:40 PM »
 If the noise changes pitch with the RPM's of your engine, you have a "ground loop"; typical when you power an audio device off of a vehicle. One solution if that is the case...http://www.electricalconnection.com/audio/filter-gli.htm
Kennedy has the goods too, but good luck with their web site, http://www.cellset.com/motorcycleitems.html You might just phone them. You have to call to order anyway.
Let us know when you get all jacket up! ~Jeff
« Last Edit: July 16, 2011, 08:15:32 PM by Wanderer » Logged
More Valk Pics...
had a couple of Valks once upon a time
2004 DRZ400S
2005 GS1200
1978 CB550K
1977 CB550F
