Big Daddy
« on: June 22, 2011, 04:23:13 PM » |
I'm new to both the VRCC and the Valkyrie I/S. Love the bike, but will ride solo most of the time. Strongly considering converting the bike to a Super Valk. At times I'll have a passenger so the option to convert back to ride double at times would be good. Just not exactly sure where to begin. Any assistance would be welcomed and appreciated.
Thanks. BD
The Anvil
« Reply #1 on: June 22, 2011, 04:26:35 PM » |
Forgive my ignorance, but what exactly is a SuperValk?
Boxer rebellion, the Holy Child. They all pay their rent. But none together can testify to the rhythm of a road well bent. Saddles and zip codes, passports and gates, the Jones' keep. In August the water is trickling, in April it's furious deep.
valkyriemc
NE Florida
« Reply #2 on: June 22, 2011, 04:42:19 PM » |
Go to "Old Tech Archive" type in supervalk, and you will find many, many posts and some pictures.
Veteran USN '70-'76
The Anvil
« Reply #3 on: June 22, 2011, 04:49:10 PM » |
So it's basically an I/S with the trunk removed? Is that right?
valkyriemc
NE Florida
« Reply #4 on: June 22, 2011, 05:50:38 PM » |
Yowser, and then adding a rear tailight assembly and a removeable small type "sissy bar", and changing the seat. It looks pretty good, I just dont want to give up my I/S trunk space. Take a look at this thread on the general board; http://www.valkyrieforum.com/bbs/index.php/topic,28676.0.html
Veteran USN '70-'76
Big Daddy
« Reply #5 on: June 22, 2011, 08:15:11 PM » |
Thanks for your help, much appreciated!
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #6 on: June 23, 2011, 06:40:20 AM » |
Don't know if this page is part of what Valkyriemc posted, but here is a step by step, in pictures, on how to convert the trunk mounting brackets to 'quick release'. Big BF (Bill Furgeson) is a member and a club sponsor. Lotsa cool ideas on his site. http://bigbf.com/bigbf_shop/mod_i-s_trunk/Black Dog
Just when the highway straightened out for a mile And I was thinkin' I'd just cruise for a while A fork in the road brought a new episode Don't you know... Conform, go crazy, or ride a motorcycle...
Pete
« Reply #7 on: June 23, 2011, 07:49:54 AM » |
If you want 2 up capability, then leave the IS seat and add the standard passenger back rest.
While not a true "SuperValk" IE single seat, no back rest, it still looks good and has 2 up capability.
And by swapping to single seat and removing the backrest and installing a short low bar you can easily become a true "SuperValk".
Search the web and you will find a quick attach/detach trunk mod that is also nicely done to approach SuperValk look and feel.
The possibilities are endless.
By removing the trunk you remove several pounds of top heavy weight. I find that I like the way the bike feels, handles and rides without the trunk.
Have fun.
Big Daddy
« Reply #8 on: June 23, 2011, 09:15:48 AM » |
I have noticed a top heavy feeling to the bike and was hopeful that removing the trunk would eliminate some of that top heaviness and improve handling, particularly at slower speeds. Thanks for the insight. BD
mirion
1997 Std - 2000 IS
Frankenmuth, Michigan
« Reply #9 on: June 23, 2011, 09:26:09 AM » |
You can't add the standard backrest without changing the fender rails that it mounts to, the IS fender rails won't accept the backrest brackets. That is what I did and use the Ultimate Lowboy seat. Four bolts removes the backrest and shown is the cruiser bar in its place.  My standard has a IS tank but there I use a Corbin seat with the nose trimmed back to fit the bigger tank and I use the Corbin plug-in backrest making removing the backrest a tool-less process or three bolts gets the rear seat off quick for totally solo.
« Reply #10 on: June 23, 2011, 09:33:01 AM » |
You will find it a lot less burdensome with the trunk removed, not forgetting to mention, the reduced weight which will lessen that "top heavy" feeling! ***
MP
North Dakota
« Reply #11 on: June 23, 2011, 03:50:55 PM » |
I liked the IS at Johnson City Inzane where he moved the trunk ahead so the solo rider can use the backrest of the IS trunk. anyone have pics and/or instructions?
MP
 "Ridin' with Cycho"
Paxton
« Reply #12 on: June 23, 2011, 03:55:00 PM » |
valkyriemc; As you suggested, I went to the archives and came up empty handed on the supervalk topic. ???
J. Paxton Gomez
1966 First year Bronco... 302 CI V8 1975 First year Chrysler Cordoba... 360 CI V8 1978 Honda 750F / Cafe Racer 2000 GL1500CY Fast-Black Standard Solo Rider
So Cal... 91205
valkyriemc
NE Florida
« Reply #13 on: June 23, 2011, 04:45:06 PM » |
valkyriemc; As you suggested, I went to the archives and came up empty handed on the supervalk topic. ???  Sorry you had problemos... I went to tech board archives, the dates are set, typed in supervalk and over a hundred posts were there. Once I typed in petcock and there had to be over 500 posts of every sort of petcock issue. I mean my point in archives is a lot of this stuff has been thoughly hashed out in past years, although new fixes can come about too. I've been particpating on tech and reading it since 2002.
« Last Edit: June 24, 2011, 01:59:30 PM by valkyriemc »
Veteran USN '70-'76
« Reply #14 on: June 23, 2011, 05:22:18 PM » |
A true " Super Valk " has the trunk stay notched for easy on / off ( add the trunk or remove the trunk in about 5 minutes ) . Lots of folks has a Interstate with the trunk removed but that's not what a Super Valk is as much as they'd like to call it a Super Valk it is'nt.
Challenger
« Reply #15 on: June 23, 2011, 05:43:31 PM » |
I have mine super-valked with the brackets notched, when removed and riding two up, I have an 04 Intruder backrest by cobra that I drilled two holes ahead of the rear ones to mount onto the factory trunk studs, 5 minutes to remove pillion and backrest for solo, 15 minutes and the trunk is back on and wire harness connected for vacation
« Last Edit: June 23, 2011, 06:06:56 PM by Challenger »
Paxton
« Reply #16 on: June 23, 2011, 09:56:20 PM » |
"Paxton, here's what I got on old tech archive search, I'll erase it after you eyeball it, let me know..." valkyriemc, thank you. Go ahead and erase it.  This Club Rocks!
J. Paxton Gomez
So Cal... 91205
« Reply #17 on: June 24, 2011, 09:58:33 AM » |
Sure it is! Notch or not. ***
« Reply #18 on: June 24, 2011, 12:49:07 PM » |
Sure it is! Notch or not. *** It goes without saying then ...You are one of them that has a Interstate with the trunk removed.It's your bike call it what you will but when the term " Super Valk " came into play it was because the trunk could be added and removed in about 5 minutes.All you have is a Interstate with the trunk removed... I know Super Valk sounds cooler than Interstate with the trunk removed but it is what it is .
mirion
1997 Std - 2000 IS
« Reply #19 on: June 24, 2011, 01:39:18 PM » |
I once had someone tell me "it ain't solo unless the rear pegs are removed and the holes are welded shut".  ........ But I think they were kidding.
Paxton
« Reply #20 on: June 24, 2011, 11:09:52 PM » |
 Color me confused. Isn't mine a "Supervalk?" Let's see... ??? 1. I own a Super Dooper bike... the fastest on the Planet!  2. It happens to be a Black 2000 Valkyrie I/P = Interplanetary.  3. There is no trunk to take on or off. (I could buy one... err... then take it off.)  4. It has superb features... it rivals the space shuttle... but it's FASTER!  5. It is the ultimate Fat-Dude-Bike! Skinny people don't look good on it!  6. It roarrrrs... like a Super Dragon...  7. It waits for speedin' bullets So... is it a Supervalk or a UFO? https://picasaweb.google.com/103917731019176896112/SUPERVALK?authkey=Gv1sRgCOHZr9G19JjrdQ# "I lie to myself all the time, but I never believe me!"
J. Paxton Gomez
So Cal... 91205
Six Guns
« Reply #21 on: June 25, 2011, 05:37:40 AM » |
Paxton
Private Message Sent.
« Reply #22 on: June 26, 2011, 12:54:58 PM » |
 Color me confused. Isn't mine a "Supervalk?" Let's see... ??? Yep, confused you are (on several counts) but you're not alone.
The term "Super Valk" was coined several years ago by a rider who came up with the mod to allow the trunk to be easily removed and re-mounted.
Some riders decided they wanted to remove the trunk and never put it on again. They erroneously began to use the term.
As someone else has said, you can call your bike whatever you want, but those who know what is a Super Valk will be able to recognize what is and what isn't.
The Anvil
« Reply #23 on: June 26, 2011, 02:08:18 PM » |
Mine's not even an I/S and I call it a "Super Duper Ultramega Valk".
Momz
« Reply #24 on: June 26, 2011, 05:08:33 PM » |
Call it what you will, but this is what I have.
 ALWAYS QUESTION AUTHORITY! 97 Valk bobber, 98 Valk Rat Rod, 2K SuperValk, plus several other classic bikes
Chrome
London Ontario Canada
« Reply #25 on: June 26, 2011, 05:21:46 PM » |
Maybe not a "Super Valk" to some but very happy with my ride.  Chrome
« Last Edit: June 26, 2011, 05:44:18 PM by Chrome »
2001 Valkyrie I/S 1999 Valkyrie I/S 1998 Valkyrie Tourer 1998 Ace Tourer 1984 V45 Sabre 1976 CB 750 SuperSport 1969 CB 750 Chopper
« Reply #26 on: June 26, 2011, 05:39:12 PM » |
I think it all depends upon how you hold your mouth when sucking on a lemon.  ***
scoot
Lifes too short Ride it hard
Grand Rapids Mi.
« Reply #27 on: June 26, 2011, 06:17:18 PM » |
« Reply #28 on: June 26, 2011, 08:14:33 PM » |
I think it all depends upon how you hold your mouth when sucking on a lemon.  *** You've heard it all your life ol' one with a Interstate with the trunk removed ....The truth hurts
The Anvil
« Reply #29 on: June 27, 2011, 05:00:19 AM » |
I think calling a Valkyrie with a removable trunk a "Supervalk" is kind of outta line whether you need to cut the trunk off with a torch or just pop it off. "Convertivalk"? Sure. But Supervalk should be reserved for supercharged Valks.
X Ring
VRCC #27389, VRCCDS #204
« Reply #30 on: June 27, 2011, 07:25:58 AM » |
Maybe cause "Blown Valk" describes those with superchargers. Doesn't matter what you think cause the term Super Valk was coined by the first guy to convert his I/S with a quick release/replace trunk. That term was accepted by those that ride Valks in this and other clubs and Johnny Come Latelies like you and me, I've had Sandman over 4 years now, don't have the right to complain about, much less try to change, the name. Marty
The Anvil
« Reply #31 on: June 27, 2011, 08:10:07 AM » |
Maybe cause "Blown Valk" describes those with superchargers. Doesn't matter what you think cause the term Super Valk was coined by the first guy to convert his I/S with a quick release/replace trunk. That term was accepted by those that ride Valks in this and other clubs and Johnny Come Latelies like you and me, I've had Sandman over 4 years now, don't have the right to complain about, much less try to change, the name. Marty I'm not complaining. I don't care enough to complain. That's for people who like to split the very same hairs hairs stretching across their butt-cheeks. It's just an observation the the moniker is inappropriate.
