February 02, 2026, 07:51:22 PM *
Author Topic: NEED NUT CAGE MOD INFO ASAP  (Read 1772 times)
glenh
SW Minnesotio
« on: June 25, 2011, 06:13:30 AM »
I'm taking a Gen. Altimax 205/60-16in in less than an hour to get installed, I have the 55 series on now, looks like plenty of room for the 60, but just in case, where are the directions for doing the nut mod, I couldn't find them in Shop Talk, i read it someplace, but don't remember. Thanks
"God created man. Sam Colt made them equal"
« Reply #1 on: June 25, 2011, 06:27:20 AM »
Here's Daniel Meyer's version:
http://lifeisaroad.com/stories/2005/08/24/valkyrieRearFenderNutCageMod.html
glenh
SW Minnesotio
« Reply #2 on: June 25, 2011, 06:32:52 AM »
That's what I was looking for, thanks, easier than I figured.
B
Capital Area - Michigan
« Reply #3 on: June 25, 2011, 06:45:27 AM »
Do the mod while the wheel is off and either flip the bolts or put a washer and hex nut on the right side. My '60' rubbed until I did all this.  My2Cents.  B
X Ring
VRCC #27389, VRCCDS #204
« Reply #4 on: June 25, 2011, 07:22:57 AM »
Really?  You couldn't find "Valkyrie Fender Nut Mod"  in Shoptalk?
Marty
MacDragon
My first Valk VRCC# 32095
Middleton, Mass.
« Reply #5 on: June 25, 2011, 12:17:26 PM »
The very last item in Shoptalk.
Patriot Guard Riders
glenh
SW Minnesotio
« Reply #6 on: June 25, 2011, 12:24:38 PM »
Just got my 60 series tire mounted, there is almost 2" from it to the nut cages, no need for any mod. I put 26 lbs of air in it,rides and handles great.
Paxton
So Cal
« Reply #7 on: June 25, 2011, 03:10:38 PM »
If you did not have to do the nut cage mod, your shocks are probably at their highest setting.
Notwithstanding, test it.
Get your fattest friend to ride with you as a passenger...  2funny
I hope not, but it might make those 2 inches disappear.
You might also have to increase tire pressure with lots of weight behind you.
Good luck!  cooldude
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #8 on: June 26, 2011, 11:54:45 AM »
i run that same altimax.... 26 lbs. seems lite, especially on a new tire.  believe me, when you put any weight on that back end....it's going to rub.
