February 02, 2026, 07:50:59 PM
shock adjust tire rubbing
Topic: shock adjust tire rubbing (Read 1527 times)
Ferris Leets
Catskill Mountains, N.Y.
June 26, 2011, 03:41:25 PM »
I found the problem. The left side measures from fender to tire 1", left side 2". I need to shim the fender over .5". When I installed the car tire I thought I had it a lot better than that. Now I have to go back and look to see what I did wrong. The shocks are set on 2 so that explains why the extra weight cause the rubbing.
Thunderbolt
Worthington Springs FL.
Ferris
June 27, 2011, 03:06:17 AM »
do a search for "washer mod". It will move your fender over enough to clear.
Cliff
Manchester, NH
Re: Ferris
June 27, 2011, 03:42:52 AM »
Quote from: Thunderbolt on June 27, 2011, 03:06:17 AM
+1 worked for me, I used washers stacked to about 3/8" thickness - no more rubbing!!
VRCC # 29680
Ferris Leets
Re: shock adjust tire rubbing
June 27, 2011, 04:08:26 AM »
When I installed the tire I did the washer mod. Apparently not enough or else something shifted.
Cliff
Manchester, NH
June 27, 2011, 10:19:11 AM »
Quote from: Ferris Leets on June 27, 2011, 04:08:26 AM
How thick were your "stacked" washers?
VRCC # 29680
