February 02, 2026, 07:51:03 PM
HEAD LIGHT ADJ INTERSTATE
Topic: HEAD LIGHT ADJ INTERSTATE (Read 1478 times)
Poor Ol Harry
Baytown,TX. East of Houston
June 27, 2011, 01:12:58 PM »
I bought a shop manuel on a disk when I got my Interstate......couple years ago & used it a few times....thing is I have my faring open now & need to adj. my headlight while I'me there but no manuel.....can someone please point me to the adj.spot. Thanks Harry
Re: HEAD LIGHT ADJ INTERSTATE
June 27, 2011, 01:35:26 PM »
http://valkyrienorway.com/download.html
There are a few different instruction manuals also.
June 27, 2011, 02:56:12 PM »
They are adjusted by two knurled knobs under the headlight, should not have to take apart the fairing to access them. one is up and down, one is sideways left and right, don't remember which is which. Hoser
Last Edit: June 27, 2011, 02:57:47 PM by Hoser
3W-lonerider
Shippensburg Pa
June 27, 2011, 04:04:04 PM »
if you reach into the fairing under the handle bars you'll find 2 grey knobs that will turn. theres one for each light. they are the up and down..your side to side adjustments are 2 10mm bolt heads at the bottom of the light assemblies..you should'nt have to adjust those..just the 2 grey knobs.
Poor Ol Harry
June 28, 2011, 12:07:01 PM »
Many thanks to all......I found the adj. nobs & got it done.....really a pretty simple operation I'da thought someone in the business would have had no problem with it but .....instead I was told the lights were adjusted as far down as possible(on second thought that was no problem).....It was great for coon hunting!
