April 30, 2026, 11:18:13 AM *
Author Topic: Leaking Right Front Fork Seal  (Read 10637 times)
Six Guns
Fort Worth, Texas
« on: June 29, 2011, 05:33:40 PM »
I have a leaking right front fork seal on my 98 Tourer. If I'm not going to replace the springs, I understand that I don't need the Honda special tool to do the job. Is that correct? This a list of parts that I compiled to do the job. Did I forget anything? TIA
BUSH GUIDE
51414-MT7-003                2EA X $13.89 = $27.78
SEAL SET, FR. FORK
51490-MW0-003               2EA X $21.17 = $42.34
BUSH, SLIDER
51415-MCH-003                2EA X $6.52 = $13.04
O-RING (44.7 X 2.4)
91356-KZ3-003                 2EA X $2.50 = $5.00
Valkpilot
What does the data say?
Corinth, Texas
« Reply #1 on: June 29, 2011, 07:08:27 PM »
BUSH GUIDE
SEAL SET, FR. FORK
BUSH, SLIDER
O-RING (44.7 X 2.4)
Can't remember the full parts list, SG, but the DFW Football has the fork tool in it in case you want to do the Full Monty.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #2 on: June 29, 2011, 07:18:57 PM »
While you in there....
http://cgi.ebay.com/ebaymotors/PROGRESSIVE-FORK-SPRINGS-HONDA-VALKYRIE-GL1500C-97-03-/390320807665?pt=Motorcycles_Parts_Accessories&hash=item5ae0eedef1
The difference is night and day SG.
laserpat
Cedar Park, Texas
« Reply #3 on: June 29, 2011, 09:04:41 PM »
Don't forget fork oil and a measureing cup
Doc809
« Reply #4 on: June 30, 2011, 12:58:53 PM »
Hey Victor, Serk just had Xander's Cycles in Forney do a complete rebuild on his front end seals.  If I remember corrrectly $200 parts and labor.  Just an option.  I know I would not try to tear it down for that.
How much fun can I have before I have to go to hell?
Six Guns
Fort Worth, Texas
« Reply #5 on: June 30, 2011, 01:09:44 PM »
Doc,
 Thanks for the tip.   cooldude
Baron
Trophy Club, Texas
« Reply #6 on: November 06, 2011, 05:05:05 PM »
Victor,
Did you rebuild the forks?  Any suggestions because my right front fork is leaking.  I think I may give Xander's Cycle a call for $200.
Ride safe,
Baron
VRCC 28275
2000 Valkyrie Interstate
2023 Road Glide Limited
2022 KLR 650
lucky_1_chris
Arlington, TX
« Reply #7 on: November 06, 2011, 09:25:48 PM »
Victor,
The special tool is for the left fork. You can drive the seal and bushing in with a piece of PVC. You can also use a piece of 35mm film and push it up between the fork leg and seal to dislodge anything that might be causing the leak. Worth a shot before you tear it down or pay a shop to do it. I'd bet that $200 is with the forks removed...
1999 Valkyrie Interstate
Six Guns
Fort Worth, Texas
« Reply #8 on: November 07, 2011, 04:57:50 AM »
Victor,
Baron,
  I have not. I've been riding the Interstate while the tourer right fork seal is still leaking in the garage. I have to work every other weekend and it seems that when we have a wrench party, I am working. I might just break down and take it to Cycle Werkz in Fort Worth and have it done. I have already purchased all the replacement parts needed to do the job, but I have never done one before. I have 10 days off starting the 18th of this month until the 27th. If someone wants to show me how it's done I will pay you or buy your lunch or both.     Smiley
« Reply #9 on: November 07, 2011, 06:17:57 AM »
Semi-correct. I'd ordered the parts myself before hand because I was going to try to wrench party it, but I just never got a chance to make it to one. Xander Cycles did it for $200 labor, I brought him the parts (Well, he supplied the fork oil and labor.)
It was still money well spent IMHO to just "Get it done"....
franco6
Houston, TX
« Reply #10 on: November 07, 2011, 07:42:11 AM »
Victor ,if you were a little closer ,I d ride over and gie you a hand Smiley. since you got more than one bike, take the time to do it yourself and learn. just follow the manual and thre s more than enough help on this board! cooldude
Enjoy the ride!
Dodis
'98 Blue & Cream
Texas City, TX
« Reply #11 on: November 07, 2011, 09:35:37 AM »
When I rebuilt my right fork (again  tickedoff ) this summer, instead of using the fork lower as a slide hammer on the PVC fork tool, I used a wood stand that I had built for another purpose to make a press. Used two 2x2 as handles on each side of a 2x4, just high enough to sit on the PVC seal tool while the fork tube was on the base. Pressed it in and it snapped in with authority.
And I re-used the seal I had as it was new from the earlier rebuild because I STILL couldn't find any scratches that would have been causing my seeping. Once the seal snapped in this time, it hasn't leaked since (fingers crossed!)
This could be a purpose built press, or most likely just attached to a wall stud with the fork on the floor.
Mike "Dodis"
VRCC# 27132
mr_dodis(a)yahoo.com
DS#513 GY-TT 205/60   (still waiting for my cookie!)
Baron
Trophy Club, Texas
« Reply #12 on: November 07, 2011, 05:47:03 PM »
Victor I understand.  Work and my family have been keeping me real busy too.
Some great info here cooldude.  I will try the film to see if I can clean it out first.
I called Al Lambs today and the cost of them doing my front forks was close to $350 which is more than I want to spend.  Xander's Cycle sounds more reasonable so I will call them.
I have been thinking about adding progressive springs so maybe I can talk my wife into an early Chritsmas present  Roll Eyes
Ride safe,
Baron
VRCC 28275
2022 KLR 650
Mofla
San Antonio TX
« Reply #13 on: November 13, 2011, 08:41:14 AM »
Had a m/c shop install new leaky seal on right fork.
Still leaks. Tech sezz it's leaking from the bottom (threads )
And just needs to be tightened . Truth or b/s ? Thoughts please !
Tomboy
Valker
Wahoo!!!!
Texas Panhandle
« Reply #14 on: November 13, 2011, 05:39:28 PM »
Is the oil ON the forks or just puddling on the ground and on your wheel/tire? If puddling, it IS the bolt in the bottom of the fork. You have to remove the axle enough to get the hex wrench up in the hole and tighten it. Happened to me.
Mofla
San Antonio TX
« Reply #15 on: November 13, 2011, 07:24:47 PM »
Thanks much guys !
Six Guns
Fort Worth, Texas
« Reply #16 on: November 15, 2011, 04:57:44 AM »
Baron,  did you get your leaking fork seal repaired?     Shocked
Baron
Trophy Club, Texas
« Reply #17 on: November 20, 2011, 08:01:16 PM »
Yep, I picked the Valk up Friday  Smiley.  He installed new fork and dust seals, replaced the oil, and installed new RaceTech springs for the cash price of $328.83.  I think that is a great price so if you want to give them a call  cooldude.
Owners: Robbie, Mark, and Jimmy
Rising Phoenix Motorsports
2126 Hamilton Rd
Suite 250
Argyle, TX 76226
940-565-0204
Brand new shop and real nice bunch of guys.
Ride safe,
Baron
VRCC 28275
2022 KLR 650
