September 12, 2025, 11:55:00 AM *
Author Topic: Side stand spring bolt broke  (Read 8404 times)
custom1
01 Interstate
SW Pa
« on: July 02, 2011, 06:24:59 AM »
When I got home from work(8 mile ride) the side stand was floppy. It wouldn't stay all the way up or down. Looked under and the spring was there. Looked closer and found the bolt it hooks to is snapped off. The fiche diagram isn't very clear but I think I need #6--- 90111-MZ8-000 special bolt.
http://www.hdlparts.com/fiche_section_detail.asp?section=148690&category=MOTORCYCLES&make=HONDA&year=2001&fveh=3475
 It doesn't show on the diagram but there is a nut and a wire holder on the top side. The wire holder is visible in the upper right of the pic.  It looks easy enough to get out from the top. Just want to make sure I'm ordering the right part. What is suppose to be in the wire holder? I know someone will say a wire. crazy2 I can't see how the wire to the switch would reach over that far.
Here is a couple pics.
I read on here about putting nickels in the spring coils to install it. Seams pretty straight forward. Am I missing anything?
John
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: July 02, 2011, 06:53:16 AM »
Only thing you're missing is order more than one. Some creative folks (not me) have replaced that bolt with a hardware store eye bolt, grade 8 for improved life.
The nut is still attached to the top part that is broken off.
sheets
Jct Rte 299 & 96, Calif.
« Reply #2 on: July 02, 2011, 08:45:48 AM »
Go to the microfische for "Frame"
>>> Sidestand Bracket = #10
>>> Bolt = #11 - Hook, Spring
>>> Nut = #19 - Nut, U, 6mm
Bone
« Reply #3 on: July 02, 2011, 09:01:08 AM »
Do you know what bent the bolt ?
I posted this in 2008 when my bolt was bent.
When my side-stand went limp I found the pin bent. I must have pushed the lift a little to far under the bike. Measured the needed clearance between the end of the lift and the side-stand. Cut a piece of 2x4 that size. I place the board against the side-stand on the floor which makes a safe stop for the lift.
I used a bolt with nuts to replace the pin, my bike shop didn't have the pin in stock.
Mr.BubblesVRCCDS0008
« Reply #4 on: July 02, 2011, 11:36:44 AM »
I built one from the hardware store a used one of their springs and then ordered the replacement from HDL. Still carrying the replacement spring and bolt in the saddlebags. It's been about four yrs now.
« Reply #5 on: July 02, 2011, 12:44:37 PM »
I think I know why that bolt will eventually break.  The metal plate with the hole in it designed to secure that bolt allowes it to bend back and forth  just a little, but over time you all know what bending metal back and forth does.  yep! crack!
When mine broke, I made a new one from a hardend bolt from ACE hardward and built it up with spacers, then ground down the fat part until it was a tight fit into that hole.  Now it cannot bend back and forth at all.......been on there for years.
That is a clamp/holder for the fuel tank vent line.  Yours is either just not in the holder (common) or its been removed, not a huge deal, but it is possible to over fill the tank and have gas pour out the vent and all over the bike if that hose isint there...........Ive never heard of it happening, just saying its possible
« Last Edit: July 02, 2011, 12:48:15 PM by Chrisj CMA » Logged
sheets
« Reply #6 on: July 02, 2011, 12:46:21 PM »
... running over something that kicks up beneath the scoot and hits the lowest part of the machine.
... running over a high curb and the lowest part of the machine drags when going over it.
... loading in a trailer or pickup with too steep of ramp so bike bottoms out on the lowest point.
... with bike on a lift, and with sidestand in lowered position, don't have the lift arm touching the stretched spring, adding additional side load to the already tensioned spring/bolt.
my guess... Yrmv,
custom1
01 Interstate
SW Pa
« Reply #7 on: July 02, 2011, 01:40:56 PM »
Yes Yes. I should have waited for your replies. I called my local Harley/Honda shop Z&M and they had the #6 bolt that I thought it was on stock. Drove over there and he brings it out....nope that's not it. So he looks through the fiche and sure enough it's # 10 on the frame diagram. Thanks sheets for the correction. I was just to fast on the trigger. So he doesn't have it on stock so we ordered it.
If I really need to ride this weekend I'll go the hardware store route and rig something up. If not I'll just wait till it comes in. Chris- I'll have to look for that stray vent hose.
« Last Edit: July 04, 2011, 09:05:00 AM by custom1 » Logged
John
Valker
Wahoo!!!!
Texas Panhandle
« Reply #8 on: July 02, 2011, 02:27:58 PM »
To keep riding When that happened to me I just got a bungee and bent one hook around the sidestand pokey outey piece and hooked the other to a saddlebag mount. Worked so well I left it for a year.   Embarrassed
RonW
Newport Beach
« Reply #9 on: July 04, 2011, 01:53:51 AM »
I'll have to take a peek at that bolt. Thanks for the pics. Intermittently my kickstand has not fully retracted. It stops half way in its swing. I nudge it with my boot, then the kickstand retracts fully. I thought that I might have bent the spring after bumping it with the arm of the lift jack, but perhaps the problem is the bolt.
2000 Valkyrie Tourer
Raverez
No good deed goes unpunished
Central New York State
« Reply #10 on: July 04, 2011, 06:18:27 AM »
I keep a small bungee cord on the bike that I used when mine off. twice.  Hook it to the side stand and to the rear peg. Works as a quick fix.
« Reply #11 on: July 04, 2011, 06:19:09 AM »
I got a screw head type bolt from the hardware. Its a SS one. Couldnt get a grade 8 in metric. I think this the reason I went with the SS one.
custom1
01 Interstate
SW Pa
« Reply #12 on: July 04, 2011, 09:36:33 AM »
I like to include pics. It saves a lot of typing. It would be difficult to explain how the stand was not working and the bolt broke off but the spring is still on there without a pic of it.
How about some pics of these various hardware store fixes?
John
« Reply #13 on: July 04, 2011, 09:54:43 AM »
I have no pix.
I put a nut on the new screw, near the head of it. Put it thru that hole in that little plate in your pick and screwed it into the side stand. Put the spring on at the head of the screw. Screwed the nut up to the spring. Turned the whole screw into the stand just enough the spring wont catch on anything. Its actually just a tad under the side stand frame so nothing will catch on it.
I used a screw type head so its easy to repair on the road if needed. The SS screw is a grade 5 I think is what the guy said. I need to back it off a hair as the spring catches every so often.
« Reply #14 on: July 04, 2011, 01:34:15 PM »
My opinion is that stainless is not a good material for that particular part. Might not rust but certainly is not strong enough for the duty it faces.
Carbon steel = much better.
Grading for stainless is not equivalent to grading for carbon steel in bolts and screws.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #15 on: July 04, 2011, 01:44:34 PM »
In my earlier post I said "Grade 8", but that is SAE. In metric, the higher grade is 10.9.
Sorry.
tbone
Bradford, il
« Reply #16 on: July 05, 2011, 11:18:32 AM »
Just my 2 cents but I would order a spare bolt,spring and nut. I have had 2 break. Keep a spare in the side bag now with the correct wrenches handy.
steve 3054
VRCC # 34853
Sanford,Fl. 352-267-1553
« Reply #17 on: September 30, 2012, 01:17:57 PM »
My spring fell off in the garage today   Cry  ...I am thinking of welding the bolt thingy back on...any thoughts?  I did not look, but how is the bolt thru the frame...is there a nut on the other side?   I have rigged a bolt and nut there for now and am waiting for the red lock tight to dry before letting bike down from the lift...
Be polite. Be professional. But, have a plan to kill everyone you
 meet.
custom1
01 Interstate
SW Pa
« Reply #18 on: September 30, 2012, 05:58:52 PM »
Yes there is a nut on the top side. 10mm I think. I don't think I would try welding it. It is very easy to change out with a new one. The piece that is in there will come right out once you get to the nut. If you have to wait for the part you can easily rig it with a bolt and a couple nuts for the time being.
John
steve 3054
VRCC # 34853
« Reply #19 on: September 30, 2012, 08:56:48 PM »
Thanks...so I guess the trick will be to get the broke off threads out???    Sounds like this will be fun....steve
« Last Edit: September 30, 2012, 09:05:06 PM by steve 3054 » Logged
 meet.
« Reply #20 on: October 01, 2012, 07:30:27 AM »
Like custom1 said, the broken threaded part will be very easily removed as you remove the nut on the back side.
Very easy!
steve 3054
VRCC # 34853
« Reply #21 on: October 01, 2012, 11:30:25 AM »
Yep! it screwed right out!!!   Parts are on order...Thanks!!!
 meet.
« Reply #22 on: October 01, 2012, 12:57:29 PM »
Good....now if mine ever breaks I know who to call.   2funny
steve 3054
VRCC # 34853
« Reply #23 on: October 01, 2012, 09:14:55 PM »
You can call me anytime John.  About $5 for bolt and new nut and washer. Should be in on Thur.  Headed to the mountains so will have to wait until next week to install.  Now to break the red lock tight... tickedoff
 meet.
0leman
Klamath Falls, Or
« Reply #24 on: October 02, 2012, 08:21:40 AM »
Fairly easy to change out the bolt.  Watch BigMac, out of SoCal, fix his while laying on his back in from of one of the cafe/vister centers at Crater Lake.
98 T
'98 Tourer
Brookfield, WI
« Reply #25 on: October 02, 2012, 09:08:13 PM »
I was on my way to the Blue Gray ride of 2009 and hooked the that bolt on a high bump while making a tight turn in a gas station and tore it right out along with the spring.  Mad6Gun had a zip-tie and my bungie got me to ground zero where Chrome helped me out. Now I carry a spare  6mm bolt with .
But I still kept checking it every couple miles all the way to Ghettysburg... I was afraid of the kickstand would drop down and throw me off while making a tight left turn.
Thanks again, Adrian for the spare!! It's still working.
vrcc # 21815
Hestround
Bucharest, Romania
« Reply #26 on: August 10, 2025, 01:07:30 AM »
I found my side stand spring and the bolt broken under my bike. From what I read here, it supposed to be a nut who holds that little snuggler, guess what ? It is bolted into the side stand, so I have to take down the side stand support, drill through the broken bolt and make a new thread.
 I've drilled with a 6 mm drill and after that with 6,4 mm, for a 8 mm thread. After that I take a 8mm by 60 mm bolt with 3 nuts, first nut to secure the spring, just next to the head,with 4-5 mm between them,  after that I put the metalic plate that holds the sensor (beware at the position, you might have to do it couple of times) and another 2 nuts, one to secure the bolt after I screw it in and the second to secure the entire thing.
This thing took me a couple of hours, drilling, threading, measuring all staff, but in the end the final result is more reliable than that 6 mm thread.
This is the little pain in the ass :
« Last Edit: August 13, 2025, 11:33:08 AM by Hestround » Logged
« Reply #27 on: August 10, 2025, 05:36:44 AM »
Wow, blast from the past. Cool
Us mere mortals are not privy to the thought process of Mother Honda Engineers, but my guess would be they decided that spring bolt to be disposable and designed it to be the weaker link, hopefully saving any other damage.
I've broken a couple over the years, (decades  Shocked) but have been able to remove the shank by using the nut at the top.
Sounds like yours absconded.
h13man
Indiana NW Central Flatlands
« Reply #28 on: August 10, 2025, 06:03:25 AM »
The issue is the square shoulder of the threaded end snaps when coming loose with mileage. Replacing with a regular bolt/nut stack up conversion (no shoulder) and because it appears to be 8mm? which is more than enough strength. Bolt selection, that's a personal choice though SS is not as tough as grade 8 but better than regular grade 5 bolts. Definitely seems to be a part that needs a regular looking at. I noticed the past two rides mine is starting get a little saggy.
Time to get down on the floor of the garage and clean it again while servicing.  Wink
F6Dave
« Reply #29 on: August 11, 2025, 07:40:50 PM »
19 years and over 90K miles ago, that 'spring hook' bolt broke 300 miles from home. I rigged up a bungee cord to hold the stand up for the rest of the trip. I stopped at a Honda shop hoping they'd have one in stock. They didn't, but gave me a free bolt of the same size.
When I got home I slipped a piece of plastic tubing and two washers over the bolt. That created a groove for the spring. It worked just like the OEM part. I ordered a replacement, which sat on the shelf for over a decade. I finally used it when the same bolt broke on my other Valkyrie.
Here's a picture of the 19 year old fix. It may be more durable than the OEM part. All that grease isn't from a leak; it's from spraying lube on the side-stand pivot.
F6Dave
« Reply #30 on: August 12, 2025, 07:31:31 AM »
Dave, thanks for posting that.  After measuring a broken part, an M6x60mm bolt would be the replacement I'd get.  Then, make up something resembling the picture.  Replacing that part by the side of the road seems hard, but I might stash that replacement item on the bike with my spare fuses.
Now, if a metric class 10.9 bolt (check the head) is available, I'll get that one.  Metric 10.9 is roughly equivalent to SAE grade 8.
That 8.8 bolt was what the dealer gave me. I think they felt bad about not having the part in stock so didn't charge me. It had the exact same threads and length as the OEM part.
When I got home, I had some plastic tubing on the bench that fit tightly over the bolt. So I cut about a 1-1/2" piece and added the two washers, and it was nearly a perfect match.
Using the nickels (I used washers) is nearly a must. That spring is so stiff that I couldn't stretch it with any tool I had laying around. So, I bent the spring back and forth, inserting washers into the gaps until it was long enough. As I remember they all fell out when I stretched the spring with the stand.
