August 23, 2025, 07:18:54 AM *
Author Topic: Is this a good battery?  (Read 1694 times)
rikb
Mesa, AZ
« on: July 05, 2011, 11:56:46 AM »
Been having intermittent starting problems lately.  Looking at some of the existing posts with similar problems, I note a recurring suggestion of replacing the battery.  How can you tell for certain it's ready to be replaced?
Mine shows 12.88v after a trickle charge, 12.71v after riding, 8v during starting and 13.2+v at idle.
The engine turns over easily but does not fire when the starter button is pushed and then the throttle is opened .  When the throttle is closed, it usually starts, but at an idle rpm.
Any thoughts?
Bobbo
Saint Charles, MO
« Reply #1 on: July 05, 2011, 12:02:49 PM »
The 8 volt reading during starting is a concern.  Typically a load test of 1/2 the CCA for 15 seconds fails if the voltage drops below 10 volts.  If this battery is over 3 years old, I recommend replacement.  If still within warranty, take it in and let them test it to see if it still has proper capacity.
« Last Edit: July 05, 2011, 12:08:33 PM by Bobbo » Logged
rikb
Mesa, AZ
« Reply #2 on: July 05, 2011, 01:26:33 PM »
Thanks Bobbo.
Well, I looked it up and I bought this battery in Jan of 2005, so I guess it has served it's time-in-grade adequately.   But, it is turning over and spinning the engine like usual so didn't want to replace if it is still good.
Someone had mentioned possible vacuum leak on cylinder 6, so I rplaced that hose and not much difference.
So if no other thoughts, I'm shopping for a battery!
Bobbo
Saint Charles, MO
« Reply #3 on: July 05, 2011, 01:35:45 PM »
Thanks Bobbo.
8 volts is enough to keep the motor cranking, but usually won't be enough to run the ignition module at the same time.  That's most likely the cause of the starting only at closed throttle.  Open throttle while cranking causes higher pressure in the combustion chamber, which needs a higher voltage spark.
« Reply #4 on: July 05, 2011, 03:33:54 PM »
RIK: The coils need 9.6 VDC to fire the plugs. The 8V reading during cranking is the culprit. New battery my friend. Need any help? I'll be right over. Just holler.
« Reply #5 on: July 05, 2011, 03:41:14 PM »
Its the battery
Daniel Meyer
The State of confusion.
« Reply #6 on: July 05, 2011, 03:52:02 PM »
What all them ^^^ said!
CUAgain,
Daniel Meyer
« Reply #7 on: July 05, 2011, 04:46:52 PM »
Any cranking voltage below 9.5v is a concern.. While your at your friendly battery store looking at new batteries, have them perform a load test just for the heck of it.. After all, you'll be turning the old battery in anyway.. These monsters need a lot of    ' Uummph'  to roll these engines over which doesn't leave a lot left over for the ignition system.. But, while you're installing your brand spanking new battery, check and clean all the starting system connections.. 6 years from a battery isn't too bad, not all batteries are created equal..
rikb
Mesa, AZ
« Reply #8 on: July 05, 2011, 06:17:02 PM »
Woo Hoo!!
Just put the new batt in and it cranks (and starts) appreciably faster.  I guess over time I just didn't notice the gradual decrease in starting rpm.
Once again the Tech board rules supreme!!
Thanks for your help , guys.
Now I can make that weekend run to Prescott without fear of being stranded.
All Right!
Bobbo
Saint Charles, MO
« Reply #9 on: July 05, 2011, 06:20:56 PM »
Woo Hoo!!
All Right!
Have fun, and ride safe!
Remember, your observations and telling us the necessary information helped figure this out.  You should congratulate yourself as well!   cooldude
