March 24, 2026, 06:59:20 PM *
Poll
Question: How do you have your windshield positioned ?
look through it - 8 (15.1%)
look over it - 42 (79.2%)
I don't ride with a windshield - 3 (5.7%)
Total Voters: 53
Author Topic: Windshield position  (Read 1597 times)
dubsider
Flat6 baby #33034
Dublin GA
« on: July 05, 2011, 05:08:16 PM »
When I got Flat6 Baby she had a Memphis Fats 22" windshield, so I have to look through it.  I prefer to look over it especially when I ride at night or ride in the rain... What is your preference??
Mr. Nuts
Bitterroot Valley Montana
« Reply #1 on: July 05, 2011, 05:15:53 PM »
The stock windshield was too high for me and I hate looking through a windshield. The angle of the wind in relation to the windshield was also too acute which resulted in heavy buffeting. Both problems were fixed with a few cheap brackets on the bottom which tilted the shield back (and down at the top). This solved both the buffeting and adjusted the windshield top to just the right height. Many here have done this fix and I benefited greatly by their sage advice and photos...
It is amazing how much a little tilt at the bottom lowers the top!
« Last Edit: July 05, 2011, 08:20:34 PM by Mr. Nuts » Logged
“Speed has never killed anyone.... Suddenly becoming stationary, thats what gets you.” - Jeremy Clarkson
« Reply #2 on: July 05, 2011, 05:33:09 PM »
I got a (four inch?) shorter Clearview shield after looking through the
OEM windshield in a few rainstorms  Smiley ...
Since you don't have OEM windshield brackets (and they're becoming
unobtainable) a Clearview wouldn't work for you... maybe you could cut
the  Memphis Fats down?
dubsider
Flat6 baby #33034
Dublin GA
« Reply #3 on: July 05, 2011, 05:41:30 PM »
I am not sure I have the skills to cut it professionally.. for not a huge amount of money Memphis sells replacement plastic..(I just have to use the straps and mounting h/w off of the retiring shield.  I am thinking either the 17" which may be a little short, or the 19" which may be slightly tall..  If anyone in the group has cut one to size please share the technique and tools..thanks.
BigAl
« Reply #4 on: July 05, 2011, 06:25:12 PM »
Cutting one is easy.
If I can do it anyone can.
FIne tooth Jig Saw, a little sanding and you got it.
Swing an arc on a taped up windshield and a string with a sharpie on the end, cap off of course.
Then you have a radius to guide you .
DOne it before will do it again.
Al
dubsider
Flat6 baby #33034
Dublin GA
« Reply #5 on: July 05, 2011, 06:42:41 PM »
Hey Big Al...
so If I understand correctly, you put tape on the windshield ... is that to prevent splintering???
then swing an arc from a point across the tape and cut away then sand to perfection...  I may give that a try.
is that correct?
olddog1946
Moses Lake, Wa
« Reply #6 on: July 05, 2011, 06:51:45 PM »
Riding at night and in the rain, you can't see "Squat" by looking through the windshield, so looking over it is the way I go..I have a memphis shades fats,  17" that works great...but I don't like the fact that it will scratch if you look at it wrong..have to polish it every time I ride, just to ensure it's clear..even though I don't look through it, I like it to be clean and clear..
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Russell Rice
I think I can, I think I can, I think I can!
Owasso, Oklahoma
« Reply #7 on: July 05, 2011, 07:09:13 PM »
When cutting a shield, tape the heck out of it before you cut!! a roll of tape is tons cheaper than a new shield. You can use the tape to draw the arch you want to cut it at and will also protect it from being scratched up while cutting cooldude After you cut it you want to sand it down with some fine sand paper until you are happy with the way the edge looks. I use a heat gun and put some heat on it to help melt it smooth then sand then heat then sand until I like the way it looks. Just be really careful with the heat so you DO NOT melt more than you want. cooldude
dubsider
Flat6 baby #33034
Dublin GA
« Reply #8 on: July 05, 2011, 07:15:31 PM »
agree 100% I like a clean shield.. Pledge works wonders... I prefer Lemony Pledge.
bigdog99
1/1/2011 86,000 miles
Kouts Indiana
« Reply #9 on: July 05, 2011, 07:17:47 PM »
i look over, the stock shield on my IS has always caused me to stretch a little. i put the Cee Bailey's 2" shorter than stock and its great. still get good deflection and i can look over it too.
VRCC#31391
VRCCDS0239
Stanley Steamer
Athens, GA
« Reply #10 on: July 05, 2011, 07:21:09 PM »
+1..... cooldude
Stanley "Steamer"
"Ride Hard or Stay Home"
BIG--T
The Twilight Zone
« Reply #11 on: July 05, 2011, 08:36:48 PM »
I believe the rule of thumb is to have the top of the shield somewhere between the tip and bridge of your nose.  cooldude
BIG--T
The Twilight Zone
« Reply #12 on: July 05, 2011, 08:45:49 PM »
Has  anyone ever tried MEGUIAR'S  PLASTX on their  shields?
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #13 on: July 06, 2011, 03:46:20 AM »
I was trimming one with a fine toothed sabre saw, and broke the shield.  I switched to a Rotozip... bada BING done.  I made a template from the original arc of the shield, and transferred it down.  Marked it with a sharpie, and RotoZipped it off.  Then used a belt sander to smooth it out till it looked nice.
I recommend a Roto Zip.  ANd like they said... LOTS of tape.
Jabba
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #14 on: July 06, 2011, 04:54:55 AM »
I'm a "lookover" guy... I cut mine @ 17" from the top of the headlight cutout. This puts the top of the windshield roughly between the tip and the bridge of my nose. Just trace out the original pattern. Honda windshield.
  1. Better visability
  2. About the same wind protection, believe it or not.
  3. Eliminates disstorted vision (looking though, in the Florida sun)
  4. Eliminates fogging. Well it doesn't eliminate it, but you don't have to struggle to look through
      anymore.
  5. It just plain looks better
I honestly haven't discovered any downside to this. If your not sure where to cut or how much to take off, try to ride someone elses, or cut off a couple inches at a time.
  I like mine so much when it comes time to replace the windshield I will order one the same size from Clearview. Smiley
« Last Edit: July 06, 2011, 05:34:03 AM by Tundra » Logged
« Reply #15 on: July 06, 2011, 07:19:47 AM »
cap off of course.
D'OH!  Embarrassed
Oh well...
bigfish_Oh
Allis
West Liberty,Ohio 43357
« Reply #16 on: July 06, 2011, 08:10:16 AM »
good topic, before cutting my shield(wasn't brave enough yet) I was trying these options I was planning anyway. I'm in the process of tilting mine and pulling it back to fall lower with the headlight radius. I have made a gauge bracket to relocate gauges back and apart to allow 3+2 motosen's between them. I will follow with pics in a new post and do plan on making several brackets(sst,al,br). Time is closing in on INZ
I had posted the question about a F15 or F16 shield in the tech section
2012 HD Road King Classic, Teq sunrise/HD Orange
2009 HD Nightster,orange
1974 CB550F,org
1999 Valkyrie,orange/Black (20K)
2009 GMC 3500 Duramax CC Dually 4wd (new)
1957 WD45 Allis Chalmers Grandpa bought new
1982 CBX (new)
1980 CBX (6K)
1979 CB750F (new)
1958 Lambretta TV175 (Dad's new)
4
