February 02, 2026, 09:29:51 PM
Will Ultimate Lowrider seats fit
Topic: Will Ultimate Lowrider seats fit (Read 1646 times)
The Purple Haze
Proud Member # 23359 Purple '97 Std CSC Trike
Glendale, Arizona
July 07, 2011, 02:30:41 PM »
on my '97 Standard with the California Side Car Trike kit (CSC). I need to know if the rider AND passenger seats will fit. I talked with Des and another guy at Ultimate, and they had no idea. I do know that CSC says the trike was designed to accommodate Corbin seats. Unfortunately, my tired, old posterior can no longer ride on a Corbin brick! If the Ultimates don't fit, I'll have to go custom. Any help/advice will be greatly appreciated!
shortleg
maryland
Re: Will Ultimate Lowrider seats fit
July 07, 2011, 05:17:12 PM »
I helped Goody build his CSC trike and
the bigboy seat worked just fine.
Shortleg[Dave]
July 07, 2011, 05:30:02 PM »
California sidecar should be able to tell you if the stock seat mounts remain in place; if so, any seat made for the std should fit (not an IS).
shortleg
maryland
July 08, 2011, 04:37:23 AM »
All your stock mount will remain, you reuse
the front half of fender and your seat release
all stock mounting points remain.
Shortleg[Dave]
The Purple Haze
Glendale, Arizona
Re: Will Ultimate Lowrider seats fit....
July 08, 2011, 08:26:04 AM »
I helped Goody build his CDC trike and
Shortleg[Dave]
Thanks, Shortleg! I understand the same from Des. The question is whether the PASSENGER seat will fit. Did Goody use the matching passenger seat with no modification to the seat or trike bodywork?
Lew
shortleg
maryland
July 08, 2011, 06:49:45 PM »
Yes he did,worked just fine.
Shortleg[Dave]
