November 23, 2025, 09:32:20 AM *
Author Topic: HOW MUCH IS TOO MUCH?  (Read 2708 times)
BIG--T
The Twilight Zone
« on: July 09, 2011, 04:12:38 AM »
If I put a 12oz bottle of Techron in a full tank, is that too much? Or 6oz to a tank for a Std.
MP
North Dakota
« Reply #1 on: July 09, 2011, 04:38:14 AM »
No, it will be fine.  Dump it in, run it some, then let it set for a day or two with it in the carbs.  Then, run it out.
MP
"Ridin' with Cycho"
BIG--T
The Twilight Zone
« Reply #2 on: July 09, 2011, 05:00:53 AM »
Doesn't the package say "treats up to 12 gallons"?  How much does your tank hold?  Five or six?  Seems like half a bottle is what they recommend.
I put too much Sea Foam in a bike one time.  It ran poorly as the stuff isn't gas.  Best to follow the label.
Good luck with it.
Yes it is a 12oz bottle and I've always put 1/2 a bottle in other bikes for a 5+ gallon tank but was FI. But I have read many posts here where people put the whole bottle in. It seems too much might be bad on rubber and diaphrams? crazy2
9Ball
« Reply #3 on: July 09, 2011, 06:11:48 AM »
Well, it reads like Mr. MP had no troubles using the whole bottle.  Would that be more effective than two treatments at 6 oz. per tank?  I don't know.  My Father-in-Law used to say "If in doubt, read the instructions".
you're asking for an awful lot!!!!   Grin
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #4 on: July 09, 2011, 08:05:28 AM »
Good luck with it.
Pluggy ole buddy.    How much SeaFoam did you put in?    I've put TWO (2) full cans in my Tourer a couple of times and it did not effect the sound, running, starting or anything.        It did however clean up my low speed jet problem.
PS:  242K+ miles and still running the 35's.
TJ
Lake Placid , Fl.
« Reply #5 on: July 09, 2011, 09:02:43 AM »
The whole bottle will NOT hurt it.... Been using it like that for at least 25 yrs...
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #6 on: July 10, 2011, 10:24:10 PM »
And if that doesn't help, try following them.
Seriously, I had great results using 1/2 bottle of techron, driving the bike 20mph in 5th gear with the choke on for 5 minutes.
It completely got rid of a low speed miss and improved low RPM performance.
Save a horse, ride a Valkyrie
Mr Steve
Feeding Hills, MA
« Reply #7 on: July 10, 2011, 11:10:57 PM »
I toss a full "treats 12 gal" bottle into a full tank on my standard once every spring.  Periodically throughout the year I'll put in the recommended amount as general maintenance.  Have not had a clogged jet problem in the 11 years I have owned the bike.  Whether that is due to the Techron or not, no way to tell for sure, but it hasn't damaged it any.
BIG--T
The Twilight Zone
« Reply #8 on: July 11, 2011, 05:05:41 AM »
I don't know if a partially clooged jet is even my problem but it can't hurt. To recap; She runs great at low speeds but at hwy speeds I notice at 75 giving her WOT she is real sluggish but if I back off the throttle a hair -she will start picking up speed. It takes a lot longer to hit 100. I have staightened my vent hose and opened my cap and still the same. It never done it till it hit the 90's but don't run hot. I hear a lot about low speed jets clog but do high speed jets cog??
« Reply #9 on: July 11, 2011, 05:27:19 AM »
Next time the tank is off, check the fuel strainer above the petcock, might want to purchase one in advance as I hear they are somewhat fragile.  Also if you have an inline filter get rid of it.  Sounds like you aare starving for fuel at high speed/loads.
BIG--T
The Twilight Zone
« Reply #10 on: July 11, 2011, 05:46:35 AM »
I don't know if a partially clooged jet is even my problem but it can't hurt. To recap; She runs great at low speeds but at hwy speeds I notice at 75 giving her WOT she is real sluggish but if I back off the throttle a hair -she will start picking up speed. It takes a lot longer to hit 100. I have staightened my vent hose and opened my cap and still the same. It never done it till it hit the 90's but don't run hot. I hear a lot about low speed jets clog but do high speed jets clog??
You are right, she must be starving for fuel because I failed to mention she sounds great. No skipping, sputtering...nothing. BTW, Bike only has 10k and tank has never been off so the vent hose isn't kinked
Paxton
So Cal
« Reply #11 on: July 13, 2011, 12:55:42 AM »
Embarrassed Embarrassed Is Techron a fuel-system cleaner?  Undecided Is it the "Same" as the Lucas product?
If Techron is the way to go, where do I buy it?
Embarrassed Roll Eyes 2funny
“Live free or Die…”
So, is every prisoner in New Hampshire is put to death?
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
Mr Steve
Feeding Hills, MA
« Reply #12 on: July 13, 2011, 02:00:34 AM »
This can also be the symptom of a failing petcock diaphragm or petcock vac line.
« Last Edit: July 13, 2011, 02:02:26 AM by Mr Steve » Logged
Mr Steve
Feeding Hills, MA
« Reply #13 on: July 13, 2011, 02:06:16 AM »
“Live free or Die…”
Techron is a fuel system cleaner.  Some feel it better then sea foam (I am one).  I am not familiar with the Lucas product.  You can get it at Autozone.  You can also get it in Chevron gas, if you live near a station.
mario
NW Houston, TX
« Reply #14 on: July 13, 2011, 07:40:22 AM »
the chevrons and texacos, in the houston area anyway, have techron added to their ethanol induced gas.  i try and hit them to fuel up whenever i can.
Mario
01 Valkyrie Standard (sold)
12 Suzuki V-Strom 1000
« Reply #15 on: July 13, 2011, 07:40:58 AM »
The one Lucas product that has received the accolades is "Regane"
Lucas make a plethora of fuel system additives.
« Reply #16 on: July 13, 2011, 09:39:21 AM »
Gumout makes regaine and I give it 2 thumbs up. To bad it dont last.
