November 19, 2025, 02:39:26 AM *
Author Topic: Tire plugs  (Read 4233 times)
Bill Laslett
U.S.Navy 65-71
Redford, Michigan
« on: April 22, 2009, 01:34:48 PM »
How many would plug a rear tire with less than 500 miles on it ? E3...what kind of plug would use ? coolsmiley
Of all the things I've lost....I miss my mind the most
flatsixrider
2000 Standard
Greenville, SC
« Reply #1 on: April 22, 2009, 01:43:33 PM »
Where is the puncture, tread or sidewall?  IF I was to patch, I would remove and have it done from the inside.
Sometimes the appropriate response to reality is to go insane.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: April 22, 2009, 02:06:17 PM »
I plug and run them until they wear out. I prefer the 'caterpillar' plugs. My favorites are sold by Patchboy.com
daytona
Port Orange, FL
« Reply #3 on: April 22, 2009, 02:22:14 PM »
I"ve used the rope type on a rear and never gave it a second thought! But if its always there buggin ya! get it done by a pro.   coolsmiley
« Last Edit: April 22, 2009, 05:25:51 PM by daytona » Logged
Just started!
Steve K (IA)
Cedar Rapids, Iowa
« Reply #4 on: April 22, 2009, 02:45:28 PM »
I have never had a problem using the gooey string type plugs with the glue.  Most Auto stores sell the kit...strings, glue, rasp and insertion tool.  I keep one in my saddle bag.
States I Have Ridden In
Grandude
« Reply #5 on: April 22, 2009, 03:28:55 PM »
A plug is temporary so any kind will do. A patch is the only permanent repair.
Any professional tire person (or safety advocate) worth his salt will tell you to use a plug only to get you to a place where the punctured tire can be patched from the inside. And it should only be patched if it's punctured in the tread. If it's punctured in the sidewall, it's time for a new tire.
I have run tires all my life with patches, but never with plugs because I have seen too many leak down.
If you run a patch very long you need to ask yourself, do you feel lucky?
dreamaker
Harrison Township, Michigan
« Reply #6 on: April 22, 2009, 03:34:55 PM »
I use the mushroom type for years and never failed. I had to use it on my Valk. once never had a problem. I just this kit for the road.
Dan
http://www.directlineparts.com/product.asp?pid=753&str=2
Valker
Wahoo!!!!
Texas Panhandle
« Reply #7 on: April 22, 2009, 04:40:08 PM »
[/quote]
[/quote]
Sorry, I guess I'm an exception to this. I have been both a professional tire guy (10 years) and a professional safety advocate (17 years), and I run plugs in the tread for the remaining life of the tire. I've never had a plug leak or come out. The longest I've run one on a bike is 17,000 miles before the tire wore out. Lips Sealed
daytona
Port Orange, FL
« Reply #8 on: April 22, 2009, 05:24:24 PM »
If it leaks down its no worse than another nail or drywall screw! (hate those) I had a new set of tires on my sport bike, heading for Robinsville N.C.. Got to Aiken S.C. while at a gas stop noticed a drywall screw in my front Qualifier. Pluged it and pumped it up! Checked the psi every stop, it was on my mind bugin me the whole trip. Mostly in those decreasing turns. Rode back to FL without a PSI loss and the rest of the tire life! Maybe why I didn't get a ticket that trip!
Just started!
Garland
#618
Hendersonville NC
« Reply #9 on: April 22, 2009, 05:26:33 PM »
I also have had very good luck with the Stop & Go mushroom plugs. I have used them on both my Valk and various other vehicles, and have not had a problem yet...
fast black
centerton, arkansas
« Reply #10 on: April 22, 2009, 06:34:26 PM »
I have put a plug in my bike tire and my auto's rear tire and I ran them untill the tires  were wore out.
Just my two cents
adios
fast black
Grandude
« Reply #11 on: April 23, 2009, 10:36:40 AM »
Please don't take offense Valker. I feel strongly about this because I have had close calls and also seen many close calls because of plugs leaking down quickly at a bad time.
I might run one too long again myself one day if I have to, but I will never tell anyone that it's okay to run a plug as a permanent repair.
BTW, I'll buy a beer for anyone who can show me where a plug manufacturer intends for them to be a permanent repair. Any package I've ever seen recommends them for a temporary repair only.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #12 on: April 23, 2009, 12:54:50 PM »
No worries. I don't take offense. I have been plugging for 40 years and don't recommend to others to do it. I was just stating what I do. I also patch tubes on my bikes that run tubes....even the front ones. (I also used to climb trees and ride out thunderstorms in them, but that is off topic) uglystupid2
DeathWishBikerDude
« Reply #13 on: April 23, 2009, 01:37:35 PM »
Every tire I buy seems to get a nail in the first 500 miles.
Plug it and forget it.
 uglystupid2 cooldude
FLAVALK
Winter Springs, Florida
« Reply #14 on: April 23, 2009, 06:41:53 PM »
I've run plugs many times. Once I had two in a front Avon...ran it till the tire wore out. I've used both Stop-n-Go and Progressive plugs.
sheets
Jct Rte 299 & 96, Calif.
« Reply #15 on: April 23, 2009, 07:37:03 PM »
I've got a Stop-n-Go plug in my rear E3 as we speak.  After analyzing the situation, the size of the plug, the size of a nail, and as difficult it is to get the plug through the gun and into the tire, I can't imagine the plug ever failing.  I'm not in the tire business, but I'm riding with the plug.  Ymmv,  (I also run a mud flap on the front fender, so the theory about the front flap being a cure-all for picking up nails does not hold water).
Valker
Wahoo!!!!
Texas Panhandle
« Reply #16 on: April 23, 2009, 08:03:52 PM »
but is the front flap long enough to drag the ground? I put one on a Wing front that was long enough to drag. It wore off even with the road. In 100K with that bike, I never had a rear flat. uglystupid2
sheets
« Reply #17 on: April 24, 2009, 05:30:50 AM »
Actually, yes.  It has about three inches of fringe that touches the ground when stopped.  Its wore down to match road surface.
sheets
« Reply #18 on: April 25, 2009, 04:25:27 PM »
Actually, it's 4 1/2 inches of flap at the longest point and 4 1/2 inches of fringe at the shortest point.  The fringe drags the ground at low speed.  (drilled the fender to mount the flap. Haven't taken the time to figure out how to post pix on the new site). Ymmv,
