February 02, 2026, 09:30:15 PM
IS instrumet light color !
Topic: IS instrumet light color ! (Read 1417 times)
Biggebeacher
July 10, 2011, 05:05:58 AM »
Hello @ all,
can you change the light color in the meter/multi-display from a Interstate ?
Is there a special bulb ore LED ?
Thank you for your answer
Best regards
Biggebeacher
fordmano
San Jose, CA.
Re: IS instrumet light color !
July 10, 2011, 05:22:54 AM »
Not 100% sure myself, but I believe you should be able to get replacement bulbs in ANY color and in LED format. I sure hope so since that is 1 of the next changes I will be getting finished up over the next couple of weeks.
Belly Tank is on the way.
Saddle Bage top rails (luggage racks) on the way.
Soft Joe Rocket tank bags to be installed on above mentioned saddle bag top rail, on the way.
Last but not least, since I need to pull the fairing I am ordering new LED in either green or light blue. Green will match the cruise control lights and the light blue would match the new HID headlights and HID POD lights. I figure anywhere I can I want to install LED for the lower amperage draw they require.
I can't remember the bulb type but it's in your repair manual. But yes you can change them I don't think it will change the clock/radio display? Maybe someone else can answer that for the both of us...
What Exactly is Normal?
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
