January 28, 2026, 12:37:42 PM *
Author Topic: Help no get e up  (Read 3191 times)
bassin
Arkansas
« on: April 22, 2009, 06:09:17 PM »
Was riding on the Highway at about 65 mph, screw the throttle to pass and NOTHING just  a slow increase in speed. I backed off and tried again still no go. Rode about two more miles cranked down on the throttle and jumped to 80 in just a few seconds. It was almost like someone was holding me back. No excessive wind to matter. Any suggestions of what to check sure would be helpful.
3W-lonerider
Shippensburg Pa
« Reply #1 on: April 22, 2009, 06:19:45 PM »
yep..doing the same identical thing mine done a few years back..my petcock diaphram had a slice in it..carbs were getting gas but just enough to maintain a steady speed.
bassin
Arkansas
« Reply #2 on: April 22, 2009, 06:34:58 PM »
How did you determne that what do I need to do to see if thats the problem?
3W-lonerider
Shippensburg Pa
« Reply #3 on: April 22, 2009, 07:00:46 PM »
pull your petcock apart and see if the diaphram is torn..if so you need a cover set.
lee
Northeast Tennessee
« Reply #4 on: April 22, 2009, 07:06:11 PM »
Pull the vacuum line off at no-6 intake and hook a vacuum (hand pump) to the line
if you have one.  It should hold vacuum if its ok.  If it leaks off fairly fast then diaphragm
is bad.
Time is not what is taken but what remains.
C. Drewry
bassin
Arkansas
« Reply #5 on: April 22, 2009, 07:12:58 PM »
Thanks guys for the info and pics will tare it down tomorrow and see. Nothing worse then when you bike wont go like it should. I figured I was not the only one who had this problem.
bassin
Arkansas
« Reply #6 on: April 23, 2009, 08:29:14 AM »
Is there a good place on the internet to order the petcock. My dealer says he can have one in a week or so.
Six Guns
Fort Worth, Texas
« Reply #7 on: April 23, 2009, 08:44:22 AM »
http://www.directlineparts.com/store.asp?str=2
« Reply #8 on: April 23, 2009, 09:51:55 AM »
The test at the end of this article in shoptalk will help ensure you reassembled
the petcock properly before you put the tank back on and find out the hard way...
http://www.valkyrieriders.com/shoptalk/petcock.htm
