March 24, 2026, 10:43:13 PM *
Author Topic: I was wrong! 205/65/16 CT is taller than stock 180/70 MC tire.  (Read 1488 times)
Tropic traveler
Silver Springs, Florida
« on: July 11, 2011, 07:41:40 PM »
Butt dyno said the 205/65/16 Michelin HydroEdge I had on my '99 was upping the RPM more than the 180 Avon MC tire that was on my '97. As the pic shows I were wrong.
Anyhow, the CT is going to be a yard sale item unless any of my Florida Valk friends want it {has a hole near dead center} & the Avon is on.
Mounted & dismounted the tires on the garage floor! {Enter Tim Allen grunts here!!}
Tire machine??? I don't need no stinking tire machine!!!! 2funny
New metal stem & Dyna-beads installed.
'13 F6B red for Kim
tank_post142
south florida
« Reply #1 on: July 11, 2011, 08:22:43 PM »
larger tire = lower rpm. Am i wrong?  crazy2
I got a rock Sad
VRCCDS0246
« Reply #2 on: July 11, 2011, 09:54:46 PM »
Splain to this ole timer how a taller REAR tire is going to up or decrease your RPM's.
Stude
« Reply #3 on: July 11, 2011, 11:22:56 PM »
RJ
 I think he is talking about in relationship to a set mph... 70mph with a taller tire compared
to a shorter tire at 70mph the RPM of the motor would be different
MacDragon
My first Valk VRCC# 32095
Middleton, Mass.
« Reply #4 on: July 12, 2011, 04:44:46 AM »
RJ
That is correct.  Example: If the speedo was spot on for the smaller tire at 70mph... you would go exactly 70 miles in one hour.
With a larger tire, with the same speedo setting at 70mph, the distance would be a bit further for the same revolution... in that same hour, you would actually travel,...say... 72 miles instead of 70 miles. (rough estimate) Speedo would have still said 70mph... but you were really travelling 72 mph with it indicating 70mph.
So with a larger tire, with a goal of going exactly 70 miles in distance, and the same speedo... you could run, say, 68mph (indicated) to stop at 70 miles.  Your RPMs would be, of course, lower with the larger tire to go the exact same distance.  Cool coolsmiley
Patriot Guard Riders
Ferris Leets
Catskill Mountains, N.Y.
« Reply #5 on: July 12, 2011, 04:52:07 AM »
"So with a larger tire, with a goal of going exactly 70 miles in distance, and the same speedo... you could run, say, 68mph (indicated) to stop at 70 miles.
  Not on a bike where the odometer is on the FRONT tire.
« Reply #6 on: July 12, 2011, 04:55:26 AM »
The speedo runs off the front tire, with a larger rear (tire), @ 70 mph indicated, your RPM would be slightly lower.
BIG--T
The Twilight Zone
« Reply #7 on: July 12, 2011, 05:23:28 AM »
That taller tire would give you a higher gear thus turning lower rpm. Think it would be enough to improve mpg? uglystupid2
« Reply #8 on: July 12, 2011, 06:46:32 AM »
You hit my question right on the button.
There ain't no firkin difference in RPM with either rear tire at 70 MPH.
« Reply #9 on: July 12, 2011, 08:21:01 AM »
Well, yes, there is.
Rear tire size impacts the RPM at any given speed.  Front tire size impacts speedometer reading at any given speed.   uglystupid2
The Anvil
Derry, NH
« Reply #10 on: July 12, 2011, 08:26:02 AM »
Oh yes there is. It might be minimal when the overall diameter/curcumference is minimal but rpm at a given speed absolutely does change with tire diameter/circumference changes. Which is why people change gearing on 4X4's that get upsized tires.
designer
Columbus, Ohio
« Reply #11 on: July 12, 2011, 09:14:03 AM »
In theory, you would get better MPG since the RPM to do 70MPH is lower with a taller (larger circumference) back tire.  Each rotation would take you a little farther down the road without chaning the RPM's.  so, if you slowed down to maintain the 70MPH you would be going slower... lower RPM's.... less gas.  Since the drive tire is the back its the only one that counts when calculating RPM / MPH / MPG, the front is only the witness.
Myth busters did the same thing with an airplane trying to disprove the airplane wouldn't take off if it was on a converey belt, but the drive was the engine prop not the wheels.
2002 Valkyrie Std
K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
Stude
RJ
« Reply #12 on: July 13, 2011, 05:24:30 PM »
 Sell your house move to Missouri... the show me state. Take your bike for a ride and when you reach 70mph mark where the pointer is on the tach. Then mount a taller tire on your bike and when you reach 70mph again mark where the pointer is at on the tack.
 crazy2
designer
Columbus, Ohio
« Reply #13 on: July 13, 2011, 05:27:27 PM »
 crazy2
Won't work, if the tire is taller the speedo will be off which will give a false reading on the tach.  You'll need a gps for you speed.  But if your willing to move to Missouri then that little bit will be the lest of your expenses...... 2funny
2002 Valkyrie Std
« Reply #14 on: July 13, 2011, 06:09:28 PM »
The speedometer is run off the front wheel.  No rear tire changes that reading.
The tach measures engine speed.  No tire distorts that reading.
designer
Columbus, Ohio
« Reply #15 on: July 13, 2011, 06:13:47 PM »
You are correct, I hate it when I confuse myself.  crazy2
2002 Valkyrie Std
« Reply #16 on: July 13, 2011, 06:19:09 PM »
You're in good company.  We all hate it.  Most of us do it from time to time to remind ourselves how much we hate it.   Smiley
