February 03, 2026, 11:52:03 PM *
Author Topic: Turn Signals don't work right when it's cold out  (Read 2794 times)
RickW.
NE Ohio
« on: April 22, 2009, 08:33:51 PM »
Last year sometime I started having a small problem with my turn signals.  When it is down in the mid 40's and lower the turn signals have a time delay when turned on.  Usually after using them a few times they work properly.  When the temperature is down in the 30's it could be 10 minutes after you hit the turn signal switch before they actually work.  The switch does not appear to be the problem, it works fine.
I thought it probalby had to be the turn signal relay.  Just replaced it and the bike pretty much does the same thing.  Everything is just fine if you are above about 50 deg.
Hopefully someone else has heard of this problem with a Valk.
Rick
Momz
ABATE, AMA, & MRF rep.
« Reply #1 on: April 22, 2009, 09:18:50 PM »
Your switch is in need of service. The signals slow when the internal resistance increases. Open it up (just two screws) and spray contact cleaner into it to clean out the contaminated old grease. Then carefully grease the switch mechanism with "Dielectric Grease" (available in most auto parts stores) and reassemble. You'll be good to go.
ALWAYS QUESTION AUTHORITY!
« Reply #2 on: April 22, 2009, 10:15:02 PM »
You could fix the switch.....or move to Florida.   cooldude
« Reply #3 on: April 22, 2009, 11:02:51 PM »
Or Iowa, even the LEO's don't know what that lever is for.
RP#62
Gilbert, AZ
« Reply #4 on: April 23, 2009, 05:57:45 AM »
The old grease in the switch has hardened and is interfering with the movement of the slider in the switch.  The grease ends up being like wax - hard when cold, soft when warm.  Thats why the problem changes with temperature.  Try spraying it first as noted.  If that doesn't work, you can take the switch apart (the wires are soldered to a contact plate that stays with the bike, but the housing and slider can be removed).  Clean all the old grease out, apply new silicone grease and you're good to go.
-RP
Baloo
Rimouski, Canada
« Reply #5 on: April 23, 2009, 06:51:20 AM »
Wathever you choose, don't move to Canada, it won't help you at all!!!! Cheesy
Never ride any faster than your guardian angel can fly...
RickW.
NE Ohio
« Reply #6 on: April 23, 2009, 06:21:13 PM »
Going to take the switch apart this weekend.  I am sure that it is the problem after seeing the posts and thinking about it.
I also think the best thing is to go South.
Rick,
Pog
« Reply #7 on: January 09, 2012, 09:35:56 AM »
I was having the same problem with my bike.  A few short minutes and the problem was fixed!  Thanks!
Brian
Monroe, NC
« Reply #8 on: January 12, 2012, 07:20:00 PM »
A few shots of WD-40 worked great till I found the time to open the housing. The old grease was the issue. It is working like new now.
« Reply #9 on: January 13, 2012, 07:39:40 AM »
A few shots of WD-40 worked great.... It is working like new now.
I was reading some of the responses to my wife, getting a chuckle from some. Darn woman....sprayed me with WD-40.  Roll Eyes
« Reply #10 on: January 13, 2012, 01:52:10 PM »
Now the ? is, was that for you to get working right, or for long lasting lubrication....?
