November 23, 2025, 09:30:00 AM
D@mn Yamaha TTR 125 again
Topic: D@mn Yamaha TTR 125 again (Read 1230 times)
YoungPUP
Valparaiso, In
July 12, 2011, 05:46:45 PM »
Got this thing all together, and it wont run. Spark GOOD, completely cleaned the carb, took it ALL apart, soaked it in chemdip and reassembled it. Have been kicking this thing over for hours, and the only way I can get it to fire is to pour gas into the sparkplug hole. then it fires and dies immediately. I'm sure its something stupid, I just can't think straight as I've been banging my head on a wall with this thing.... Know you know why I ride HONDA!!!!
99 STD (Under construction)
Re: D@mn Yamaha TTR 125 again
July 12, 2011, 05:51:00 PM »
Air......its not getting air. MY RD 350 was very sensitive on the air screwes.........check it all, tweek it, hows the air cleaner........something is plugged
YoungPUP
Valparaiso, In
July 13, 2011, 06:42:37 PM »
Air cleaner -new, idle and main air screw set to factory 2 turns out, The plug doesent even get wet. I've got fuel in the bowl, but NOTHING is getting to the cylinder. ???
Russell Rice
I think I can, I think I can, I think I can!
Owasso, Oklahoma
July 13, 2011, 06:53:12 PM »
I had a dirt bike that did the same thing, found out that the kill switch was grounding out and kept it from running. Just a thought.....
July 13, 2011, 09:08:47 PM »
You probably still have clogged jet in the carb. I went through a Mazda carb and rebuilt it 3 times before "drilling" out the jet with a fine wire.
Mr.BubblesVRCCDS0008
July 14, 2011, 02:57:55 AM »
Just a thought but it has happened to me more that once. The exhaust pipe on a small 4wheeler (50cc) was plugged up by dirt dabber. The bike would start or try to start but not run. I found it by accident while checking the valves to see if one was sticking, I had the pipe off and hit the starter button and it fired to life, I pushed the pipe back on and it started to die. I had cleaner the carb at least three times pri to this with no results as for as running. Also check the vent tubing as they get plugged by mud and can give you a fit.
fordmano
San Jose, CA.
Reply #6 on:
July 14, 2011, 03:56:44 AM »
Them damn dirt dabbers (AKA: Mud Dobber, LOL
) have a tendancy to plug Sh!t up. Did you blow out all the lines coming off the carb?what about float level? I am sure you checked that but then again we all miss stuff every so often.
What Exactly is Normal?
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
=> InZane XXV
