March 25, 2026, 02:18:49 AM *
Author Topic: Mounting a flag on my Interstate...  (Read 1909 times)
Sodge
01 I/S bought 07/09 with 1,850 miles
Southwest VA
« on: July 13, 2011, 10:24:22 AM »
Any of you guys have flags on your Valks ?
Looking for a cost effective way of mounting a flag on my I/S.
Bobbo
Saint Charles, MO
« Reply #1 on: July 13, 2011, 10:28:16 AM »
Don't know if they still make them, but H-D had plastic flag holders (Flag included) for the tourpack and other mounts.  The H-D logo would come off with some carb cleaner, if you didn't want it.
The Anvil
Derry, NH
« Reply #2 on: July 13, 2011, 10:33:08 AM »
How big of a flag are we talkin? I know a dope who mounted what must have been a 4' American flag. He used pipe and u clamps and attached it to a frame rail.
Sodge
Southwest VA
« Reply #3 on: July 13, 2011, 10:35:47 AM »
Normal size for a bike... No more than a foot wide and 8 inches tall max.
X Ring
VRCC #27389, VRCCDS #204
« Reply #4 on: July 13, 2011, 11:45:08 AM »
I use Pro Pad mounts for HD FLH Saddlebag Rails.  Fit the Hondaline Saddlebag Rails perfectly.  I run the 6x9" flags but you can get the mounts with longer poles to fit 10x15" flags.
http://www.thepropad.com/Flag-Mounts-Prodlist.html
Marty
Moonshot_1
« Reply #5 on: July 13, 2011, 11:48:50 AM »
Geez, I guess that makes me a double dope.
Anyway, had a guy make a gizmo that bolts to the luggage rack. It's kinda over engineered and will easily handle extended hwy speeds. Photo is after a 60 mile escort which at times exceeded 70 mph. These are 3X5 flags and the US flag is a Tough-Tex flag.
My advice to anyone that wants to fly flags on their bike is to not skimp and look to find a cheap way. Spend the time and money to ensure that whatever you got will not come apart or break up. My set up, not including the flags was $180. While it's alot I know it ain't going nowhere but with me.
Smaller flags that you are looking to use should be fairly easy to attach to the bike and shouldn't cost much to do it. But don't be afraid to over do it.
Mike Luken
Cherokee, Ia.
ricoman
Sarasota, FL
« Reply #6 on: July 13, 2011, 03:58:34 PM »
however you mount it, remember either in the center or on the right rear.
Easy way to check, look at a post office or state or federal building. The US flag will be on your left (the flag's right) as you look at the building.
Same with your bike, if you look from the front the flag will be on your left which is the right side of the bike. The gathering of Patriot Guard guys I often see always correct those who have it wrong.
Our flag is special and deserves to be properly displayed.
tank_post142
south florida
« Reply #7 on: July 13, 2011, 04:04:18 PM »
i fly 8X10s on my antennas
I got a rock Sad
VRCCDS0246
santa
Santa Tom
Ardmore, Alabama
« Reply #8 on: July 13, 2011, 04:14:11 PM »
I fly two flags, one on each side of my luggage rack. They are the same Flags that you put in you car windows to fly, they fit on the luggage rack. I also have a 4'x2.5' flag I fly for PGR missions to honor our Vets. I made a bracket that fits on the luggage rack.
Santa
old grouch
Colorado Springs, CO
« Reply #9 on: July 13, 2011, 04:31:48 PM »
Two ways I know of that do work.  Both use a "car flag"  with the post removed.  What tank_post said, using a cable tie to anchor the flag about the height of the top of the trunk.  Don't go too high or the wind will bend your antenna.  Or you can get a piece of 1" wide by 1/8" thick flat aluminum at Home Depot or some such place, a 3' piece of 5/16" X 18 all thread, a nut to match and a chrome acorn nut (ACE Hardware) and a piece of 3/8" OD styrene tubing (hobby store) cut the aluminum to whatever length you want, round one end w/ a grinder or file, drill a hole in the rounded end and tap it 5/16" X 18, drill a hole in the square end large enough to accept the bolt that holds the chrome antenna mount.  Sand with 320 or finer wet/dry, then polish with a GOOD metal polish.  (You can get it as shiny as the chrome on the antenna mounts with a little work)  Mount the polished aluminum on top of the antenna mount with one bolt, using Blue Lock Tite.  Cut the all thread to length of the styrene plus about 3/4",  thread it into the polished aluminum, then use the nut to lock it, being sure to use Blue Lock Tite.  Slide the styrene over the all thread, slide the flag over the styrene, (a small narrow piece of the "hard" side of stick on Velcro stuck to the styrene will hold the flag nicely) add the chrome acorn nut to the top and you are done.  Lock Tite here is optional, but I reccomend it.  I can e-mail you a pick of the finished mounts on my I/S if you like.  E-mail addy is in my profile.  Stan
09/11/01 NEVER FORGET!
thumper
« Reply #10 on: July 13, 2011, 06:27:38 PM »
Don't you ever get tired of the taste of that foot in your mouth?
X Ring
« Reply #11 on: July 14, 2011, 01:43:09 AM »
I must be a triple dope.  On Patriot Guard Missions I run a 5X8' US Flag flanked by 3X5' POW/MIA and PGR Flags.  I have a flag mount that slides into my receiver hitch for those.
Marty
VALKIFIED
Sugar Grove Il.
« Reply #12 on: July 14, 2011, 08:22:50 AM »
Marty
Hey x-ring, who or did you make that flag mount ? I too am interested in one. Thanks in advance.
Some like it fast, some like it long. Valk drivers can give you both
The Anvil
Derry, NH
« Reply #13 on: July 14, 2011, 08:49:13 AM »
Marty
That's different, that's effectively a parade. This guy mounted it and just left it on all the time. Left it outside in the rain, left it on once it got tattered and had bird crap stains all over it from being parked at the beach...
That's something that really pisses me off; people who claim to be patriots and love the flag but have zero respect for it and how it's to be treated.
X Ring
« Reply #14 on: July 14, 2011, 11:49:01 AM »
Marty
I'll try to take some pics measurements and post them this weekend.  I bought mine from another PGR member who had it on his 1500 Wing trike till he totaled it.  He had another one made for the 1800 Wing that replaced it.
Marty
X Ring
« Reply #15 on: July 14, 2011, 11:52:04 AM »
Marty
Next time explain yourself better.  The way your original post reads is he was a dope for flying the flag.
Marty
Jess Tolbirt
White Bluff, Tn.
« Reply #16 on: July 14, 2011, 11:55:53 AM »
go to the local boat shop and check out thier stuff,, i got my flag at a boat shop and its top notch,,,
Valkyrie member # 23084
The Anvil
Derry, NH
« Reply #17 on: July 14, 2011, 01:36:48 PM »
Marty
Marty
This guy I'm talking about is a dope for a lot of reasons.
czuch
vail az
« Reply #18 on: July 19, 2011, 08:45:38 AM »
Good save there Anvil.  I'm with you there about the proper display and respect. I've gone back for the .99 cent store 4th-o-july patriot for a day flags that end up in traffic when they forget and lower the window. I welded a mount that bolts to the back rest and uses the package rack for extra support. I have a tripple flag setup. DONT use the caribinier clips that are made of aluminium.
Rowdy
Nerk, Ohio
« Reply #19 on: July 19, 2011, 09:52:50 AM »
If U have the flat rail rack on the trunk - the window flags can be mounted on the bracket with some modifications and tie wraps  cooldude
I just won a plaque at a poker run for having the most Patriotic bike  uglystupid2
Rowdy
99 Gr / Sv I/S
81 Bl CB900 Custom
73 Bl CL350 (sold)
06 Tit GL1800
77 GL1000 naked wing (Sold)
86 & 84 GL1200 wings (Sold)
Semper Fi "Leathernec
Rowdy
Nerk, Ohio
« Reply #20 on: July 20, 2011, 04:38:45 PM »
 Cool just luck of the draw - had not entered a contest - the poker run just selected it out of the group   cooldude
Rowdy
99 Gr / Sv I/S
81 Bl CB900 Custom
73 Bl CL350 (sold)
06 Tit GL1800
designer
Columbus, Ohio
« Reply #21 on: July 20, 2011, 07:23:39 PM »
Marty
Marty
Just admit you spoke before engaging brain, we already understand that..... Lmao
2002 Valkyrie Std
K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
