February 03, 2026, 12:46:34 AM *
Author Topic: U-Joint removal  (Read 1617 times)
fiddle mike
Nothing exceeds like excess.
Corpus Christi, TX
« on: July 13, 2011, 11:23:28 AM »
I'd appreciate it if someone could direct me to a how-to on removing the U-joint.  I wish to avoid the clusterfk I created last time out (Daniel Meyers did give excellent instructions on re-assembly).
Planning to lube shaft, final drive splines, etc.
Assume I know nothing.
Thnx.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: July 13, 2011, 11:48:58 AM »
Thnx.
Here's all you need, but you don't need to pull the u-joint for what you mentioned.
http://www.rattlebars.com/mtz/ujoint.html
fiddle mike
Corpus Christi, TX
« Reply #2 on: July 13, 2011, 12:57:59 PM »
[/quote]
Thanks, that's exactly what I need to know.
