September 17, 2025, 05:36:57 PM *
Author Topic: Sprayed all the post around the pool with WD40  (Read 614 times)
Bonzo
« on: July 14, 2011, 09:17:02 AM »
It deters Yellow Jackets from building nests! Walking around spraying every little hole with the stuff. Hey a spray can of prevention....
Woops, I'm sorry.
DIGGER
« Reply #1 on: July 14, 2011, 09:19:54 AM »
I USE WD40 ON THE GARBAGE TOO.  SPRAY A LIGHT SPRAY OVER THE GARBAGE WHEN YOU PUT THE BAGS IN THE GARBAGE CAN AND YOU WILL NOT HAVE A FLY AND MAGGOT PROBLEM IN THE GARBAGE
PAVALKER
Pittsburgh, Pa
« Reply #2 on: July 14, 2011, 09:20:11 AM »
Wooden posts?     Might deter Wood Boring Bees... but I think Yellow Jackets are ground or bush/shrub  inhabitants are they not?
John
designer
Columbus, Ohio
« Reply #3 on: July 14, 2011, 09:22:42 AM »
we have the paper nest type that build a next anywhere they can hang a next.  I like the old aerosol can with lighter trick when I find a nest.
2002 Valkyrie Std
K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
Valker
Wahoo!!!!
Texas Panhandle
« Reply #4 on: July 14, 2011, 11:38:27 AM »
If you follow your application of lots of WD40 by checking to see if you used enough (you can easily see that if you use a lit match to check), they will not rebuild. 2funny
