November 23, 2025, 11:00:04 AM *
Author Topic: Changing coolent  (Read 2665 times)
shortleg
maryland
« on: July 14, 2011, 10:35:10 AM »
   I have 4 1/2 QTS to do a change.
 Will this be enough to do it.
       Shortleg[Dave]
« Reply #1 on: July 14, 2011, 10:44:55 AM »
Ya, I think I had left overs from a gallon last time........
X Ring
VRCC #27389, VRCCDS #204
« Reply #2 on: July 14, 2011, 11:13:21 AM »
I think I used about 3 1/2 qts.
Marty
slider
mulberry arkansas
« Reply #3 on: July 14, 2011, 12:21:11 PM »
is prestone 50/50 good to use?
a proud navy veteran
9Ball
« Reply #4 on: July 14, 2011, 12:39:46 PM »
       Shortleg[Dave]
I've never gotten more than about 3-1/2 quarts in from the drain and fill....at least 5 times now.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #5 on: July 14, 2011, 12:53:00 PM »
I think that is what I used. Whatever I used, I used it because it said "silicate free" on the
label... you should check...
shortleg
maryland
« Reply #6 on: July 14, 2011, 01:54:00 PM »
  I went to Honda car dealer and got a
gallon alot cheaper than Bike dealer.
  Looked at the lable on a quart that I
had left from last change and read the same.
         Shortleg[Dave]
« Reply #7 on: July 14, 2011, 06:40:29 PM »
Remember if you get pure antifreeze to mix distilled water, not tap water.... this is why the 50/50 is good, it has distilled water in the mix.
vanagon40
Greenwood, IN
« Reply #8 on: July 14, 2011, 08:40:48 PM »
You really reckon this matters?  I did spend the extra buck and use distilled water on the Valkyrie (just because it was only a buck), but I cannot believe that tap water (through my softener) would be a problem.  Or rainwater.  Maybe really hard well water or creek water would be a problem, but I even doubt that.  I use tap water for all my other vehicles.
On the other hand, I refuse to use stop leak (or similar) in any vehicle.
X Ring
« Reply #9 on: July 14, 2011, 10:07:38 PM »
You use salt water in your cooling systems?   Shocked   With the exception of one or two systems, all water softeners replace the minerals in the water with salt so you're essentially using a weak saltwater solution in your cooling system.  I won't.  I'll pay the extra buck or two for premix.
Marty
9Ball
« Reply #10 on: July 15, 2011, 02:03:19 AM »
Marty
+1....bad thinking to use water out of a water softening system.  If it is a reverse osmosis system, then it would be OK, but since a gallon bottle of distilled water from the local Rite Aid is so cheap, why take the shortcut?
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #11 on: July 15, 2011, 04:01:18 AM »
I used tap water in my CR500  Embarrassed ...
It developed arterial sclerosis, was a mess...
« Reply #12 on: July 15, 2011, 04:04:22 AM »
salt water actually cools better than non-salt water, however salt corrrodes esp aluminum.
I use www.evanscooling.com  a little higher initial cost but it is basically lifetime after that with better cooling in the heads than a 50/50 mix
« Reply #13 on: July 15, 2011, 05:12:24 AM »
Marty
You been watching too many commercials.  Most Water sofenters now a days has salt in them yes.  But the water you use doesnt touch that salt directly.  The water flows through a tank filled with beads that attract and hold the minerals and calcium that makes the water hard.  Every so often the system creates a mild brine using the salt and refreshes the beads in the tank, the salt water (brine) is pumped out and then back to plain water going through.  Even right after its purged you cannot taste any salt, but after a couple minutes running water the remnants of any brine (salt) is washed away
X Ring
« Reply #14 on: July 15, 2011, 06:56:37 AM »
Marty
What you failed to mention is actually how they work.  The plastic beads hold sodium ions that change place with the calcium and magnesium ions from the water as it flows through the beads.  So you're replacing the mineral ion in the water with sodium ions.  You can't taste it because the concentration is too low.  When the water softener flushes it does introduce a brine solution to replace the calcium and magnesium ions in the beads with sodium ion and start the process all over again.  The brine is then pumped out where it can kill your grass or into your sewer system to affect the local waters.
I am still not putting sodium charged water in any cooling system.
Marty
Jim Ross
Nevada
« Reply #15 on: July 16, 2011, 06:58:51 PM »
You nailed it!
The salt in the water softener tank has to be replenished from time to time.  I don't want to think about where all that disappeared salt ends up.
El Cazador, VRCC#1002
Ams/Oil Dealer;
'98 Valk Tourer with too much stuff to list;
'94 Toyota RegCab short bed 4WD, 4 cyl, 5 spd;
'04 "hot rod" Ram 3500 SRW, CCSB , Cummins, 4WD with too much stuff to list;
'05 Silverado RegCab short bed 4WD, 4.3, 5 spd;
'14 Sierra SLT K1500, CCSB, 5.3, Z/71
« Reply #16 on: July 17, 2011, 04:29:50 AM »
You nailed it!
Well it pumps the brine out after it backflushes the tank and it goes down the same drain as the washing machine.  We have a septic and everything goes in there, 5 years now, and the septic guy says whatever we are doing the tank was in perfect order and the grass is fine.  So theres no terrible consequenses we can see.  We were worried about the same things, but all is good.   We go through a 40# bag in 3-4 months
BTW I use bottled distilled water or premixed 50/50 when I do the bike.  I have always just used water from the hose if I needed some for my truck
« Last Edit: July 17, 2011, 04:39:17 AM by Chrisj CMA » Logged
X Ring
« Reply #17 on: July 17, 2011, 11:33:07 AM »
All my gray water bypasses the septic tank.  Soaps and and other cleaners kill the enzymes that break down solid waste.
Marty
Farther
Quimper Peninsula, WA
« Reply #18 on: July 17, 2011, 09:38:49 PM »
So, where does your gray water go?
~Farther
X Ring
« Reply #19 on: July 18, 2011, 05:19:36 AM »
It and the output line from the septic tank meet and enter the field line which is a couple hundred feet long extending into the woods.
Marty
