January 28, 2026, 12:37:40 PM *
Author Topic: Noise in front of engine  (Read 2711 times)
MNBill
Southern Minnesota
« on: April 23, 2009, 08:13:24 AM »
My friend just bought a 1997 trike about 40,000 miles on it. He previously had a VTX. He is complaining of a whirrring noise in the front of his motor. i let him listen to mine when I revved it up and he said sounded kind of the same but he is not comfortable with the sound. I rode the bike before he bought it last fall and did not notice anything out of the normal, but that does not mean he does not have a new noise.
Are there some bearings in the front that can make that kind of a noise, I always thought it was just the belt. Tensioners go bad or something??
Leaving for Branson next week so hope to get some kind of and answer to him.
MNBill
SE Minnesota
NiteRiderF6
Doug n Stacy
Mississippi
« Reply #1 on: April 23, 2009, 10:56:46 AM »
It is probably the timing belt tensioners on the front of the engine. If those belts have ever been overtightened, it will wear those bearings out quickly. I replaced both of mine last year along with both belts.
Take the front cover off of the motor and crank it up and listen to see if the noise can be isolated. Good Luck!
Larry
Northeastern BC, Canada
« Reply #2 on: April 23, 2009, 11:17:11 AM »
It's a Valk, your friend will have to get used to it.  cooldude
