February 02, 2026, 10:57:09 PM *
Author Topic: Final drive gear lube  (Read 2350 times)
greggh
OMAHA NE
« on: July 18, 2011, 10:43:56 AM »
Mobil 1 75/90 synthetic?
Good stuff or should I get something different?
Farther
Quimper Peninsula, WA
« Reply #1 on: July 18, 2011, 10:47:05 AM »
I use it without any issues.  Probably anything that meets Honda specs is good enough.
~Farther
greggh
OMAHA NE
« Reply #2 on: July 18, 2011, 10:50:18 AM »
Thats what I was thinking.  Good to know Thanks Farther! Cool
Farther
« Reply #3 on: July 18, 2011, 10:58:19 AM »
I use synthetic because I tell myself that it will run cooler.  I don't have anything to back this up.
~Farther
Daniel Meyer
The State of confusion.
« Reply #4 on: July 18, 2011, 10:58:57 AM »
That'll do!  cooldude
CUAgain,
Daniel Meyer
tank_post142
south florida
« Reply #5 on: July 18, 2011, 11:15:09 AM »
i use synthetic in everything. my foolish butt believes it must be better because its a hell of a lot more expensive ! seriously: reports indicate less breakdown over time.
I got a rock Sad
VRCCDS0246
X Ring
VRCC #27389, VRCCDS #204
« Reply #6 on: July 18, 2011, 03:04:19 PM »
That's what I use.
Marty
« Reply #7 on: July 18, 2011, 03:16:54 PM »
There are many tests out there that prove that to be true. I even remember reading about a kid using amsoil for a school science project showing lower temps vs dino oil. He won first prize.
« Reply #8 on: July 18, 2011, 03:58:40 PM »
I use it.  cooldude
F6Dave
« Reply #9 on: July 18, 2011, 08:09:51 PM »
Been using the Mobil 1 in both Valk's final drives for over 225,000 combined miles.  I change it whenever I pull a tire.  The magnetic drain plug always has only a tiny amount of metal, which hopefully is a sign there's very little wear inside.
joefromperry
Perry, OH
« Reply #10 on: July 19, 2011, 06:27:54 AM »
I didn't know a magnetic drain plug was available for the final drive unit. I would use one. I have one for the regular oil drain on my bikes. Who makes a magnetic drain plug for our final drive units? Thanks.
2000 Honda Valkyrie Interstate Silver/Blue
2002 Honda Shadow ACE Deluxe
1972 Honda CL350K4 Scrambler
2008 Ural Patrol
1987 Honda Rebel 450
9Ball
« Reply #11 on: July 19, 2011, 07:13:34 AM »
It's already there unless you replaced it with other than OEM....next time you pull the drain plug use a Q-tip and you will clear out the muck and see the magnet.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
bg
Cumming, Ga
« Reply #12 on: July 19, 2011, 08:06:27 AM »
+1 on the mobil 1 synthetic
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #13 on: July 19, 2011, 03:02:24 PM »
the dealer probably changed the guys bike with no magnetic drain plug.......he changed the engine oil, and the final drive at the same time, and just put the final drive plug in the engine drains place, and the engine plug in the final drive.
9Ball
« Reply #14 on: July 20, 2011, 02:11:09 AM »
didn't read it that way....Joefromperry said he replaces the engine oil drain plugs with magnetic ones on all his bikes and was unaware that there was already a magnetic drain plug in our final drive units.....he will probably pipe in at some point.
1999 Standard
2007 Rocket 3
2005 VTX 1300S
