March 25, 2026, 02:19:02 AM *
Author Topic: Tire repair kits....  (Read 1554 times)
thumper
« on: July 21, 2011, 06:41:30 AM »
Looking for some recommendations on tire repair kits to carry on the bike.  Looked at the CO2 systems....60.00 with the two cans required to get the tire pressure up to 24psi.
Not sure if that's the way to go.  What about plugs and a battery operated pump?
Any help would be greatly appreciated.
SCain
Rio Rancho, NM
« Reply #1 on: July 21, 2011, 06:52:44 AM »
I carry a Stop-N-Go plug kit and a small 12V compressor, I think the compressor I got at Auto Zone is made by Slime. I have heard others also carry some string plugs too.
Steve
DFragn
« Reply #2 on: July 21, 2011, 06:53:05 AM »
I haven't had the best luck with plugs. I once plugged a hole [rather large] with a mushroom plug, but it blew out within a few miles. I used the sticky rope repair and it held well enough to get me home.
I still carry Mushrooms & Ropes + a small electric pump. I don't care for the CO2 cartridges.
thewoodman
Bradenton, FL
« Reply #3 on: July 21, 2011, 07:07:04 AM »
Since I am the one who seems to get the most flats and since I ride the most miles of the people that I ride with, I am the one who carries most of the tools. Tire kit includes a Stop-N-Go plug kit, a rope type with bubber cement and a small 12 volt compressor just in case. Most of the time, the mushroom plugs work well, but not the last time. A rope plug is still working until I get a chance to change the tires out. And when the mushroom plug failed a month ago, I had to call home and have my pump brought to me, so I never leave home without it anymore.
TheWoodMan
Cliff
Manchester, NH
« Reply #4 on: July 21, 2011, 07:14:52 AM »
I carry (all the time) the Stop n go plug kit along with inflation tool from stop n go that uses the engine compression to inflate the tire... must remove spark plug to do so.  the way the valving is setup you DO NOT introduce gas vapors into the tire.
VRCC # 29680
Jess Tolbirt
White Bluff, Tn.
« Reply #5 on: July 21, 2011, 07:25:51 AM »
i carry the rope type with me and a small air comp. i ran over a nail with the brand new rear tire and plugged it,,never had a problem and ran the tire down to the wear marks...
Valkyrie member # 23084
donaldcc
Palm Desert, CA
« Reply #6 on: July 21, 2011, 08:19:33 AM »
Cycle Pump Combo Kit.  Quality product.  I have used the compressor many times.  Hooks right to battery.  Tire gauge is also a quality product.  cooldude A little pricey until you need it.
http://www.pashnit.com/product/cyclepump.html
Don
« Reply #7 on: July 21, 2011, 08:26:06 AM »
http://www.stopngo.com/products/Standard-Model-%252d-Tire-Plugger.html
AND
A cheap air compressor from Wal-Mart
OverdueBill
Elkmont, Alabama
« Reply #8 on: July 21, 2011, 09:07:45 AM »
Rope and Wally World slime compressor.  More in the hope that if I have it, I won't need it.
« Reply #9 on: July 21, 2011, 09:57:26 AM »
As I've posted multiple times before, the plugger and reamer in these kits have small screwdriver handles which can kill your hands trying to get thru steel belt radials and car tires.  I bought string plugs (work better than mushrooms at stopping leaks) and glue, a slime pump which plugs right into the SAE battery tender pigtails on my bikes, and full size T-handle plugger /reamer from auto parts for a few dollars.
This:
Not this:
chip
« Reply #10 on: July 21, 2011, 01:11:17 PM »
Here is an earlier thread on the same product, http://www.valkyrieforum.com/bbs/index.php/topic,18438.0.html I have used it sucsesfully maybe 8 times now along with Slimes air compressor thier air compressor comes with many options for powering it  from a 12volt system.  http://www.slime.com/product/111/Power-Sport-Tire-Inflator-(%2340001).html  I bought my compressor a few years ago from Auto Zone for maybe $28.00 I am considering buying another Stop N Go tire plugger for my other bike, It may be this one instead of the gun type this time because of its compact size, http://www.stopngo.com/products/Pocket-Tire-Plugger-%252d-For-All-Tubeless-Tires.html
« Last Edit: July 21, 2011, 01:25:15 PM by chip » Logged
billyjakester
« Reply #11 on: July 21, 2011, 07:36:13 PM »
Cargol turn & go - by Gryyp
removed nail (at home) inserted Cargol turn & go and the next day rode 40 miles to tire shop.  still maintained pressure.
bill
F6Dave
« Reply #12 on: July 21, 2011, 07:50:28 PM »
I've ridden 10s of thousands of miles on the string plugs.  The worst that ever happened is 2 of them developed a slow leak.  The price is hard to beat, too.
I like the electric pumps because they don't run out or air like CO2 cartridges.  If you have a slow leak and have to ride a long way, with an electric pump you can stop and refill every few miles if you need to.
As for the size, some have removed the outer housing from a cheap 12V compressor and just carry the essential inner parts.  If you do that it requires minimal space and could possibly fit under the seat.
BigAl
« Reply #13 on: July 21, 2011, 09:24:38 PM »
The Green SLime co. makes a small compressor.
Seen a lot of stuff dug out of tires and the old fashioned hairy looking plug is the one I go for.
Not the little strips of rubber plugs, and not the damn stop and go thingy.
KISS
Keep it simple stupid is my motto.
But you need a compressor of some kind.
AL
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #14 on: July 21, 2011, 09:41:07 PM »
I keep my tire repair kit inside my tire.  It's 14 oz's of "Ride-On" sealant.
Save a horse, ride a Valkyrie
sheets
Jct Rte 299 & 96, Calif.
« Reply #15 on: July 22, 2011, 06:46:19 AM »
