August 20, 2025, 08:15:02 PM *
Author Topic: mounting gps on interstate  (Read 2456 times)
Firefighter
Harlingen, Texas
« on: July 23, 2011, 07:16:46 PM »
Wanting to add a gps to my 2000 interstate. Not sure if costly zumo or maybe a nuvi. I want to mount the device in the center where the handle bar clamp is. My bike has a (handlebar holder) a solid piece with four bolts instead of two separate clamps holding the handle bars. The mounts I have seen are designed to attach to round handle bars, not a solid plate. What are you guys doing here. I have found pictures of gps mounted in the center, but no detail of installation.  Thanks
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
PAVALKER
Pittsburgh, Pa
« Reply #1 on: July 23, 2011, 07:28:12 PM »
I mounted my RAM Mount Ball in the center of the top plate of the risers.   I have a NUVI 660 with a RAM Mount.   And I don't make it a habit of riding in the rain, so my NUVI is fine, but if I do get caught I have a little baggie that will work if need be (or I just take it off and trunk it).
« Last Edit: July 23, 2011, 07:29:54 PM by PAVALKER » Logged
John
« Reply #2 on: July 23, 2011, 07:34:49 PM »
#1 thing to do, is to find a mount for a GPS, before you buy the GPS.
I bought one, turns out there isn't a mount for it, only a universal from RAM. If I would have known, I would have bought a different brand.
« Last Edit: July 23, 2011, 07:37:26 PM by gordonv » Logged
one50npump
« Reply #3 on: July 23, 2011, 07:40:45 PM »
I have about 4 ram mount balls scattered across the cockpit. 2 on the brake lever clamp and 2 of the Ubolt type around the bars.  I use them for gps, cup holder, camera mount, all kinds of uses.
old grouch
Colorado Springs, CO
« Reply #4 on: July 23, 2011, 08:03:18 PM »
Ram makes a ball mount that replaces one of those four screws that go into the risers.  Other end is a plate that holds whichever GPS you have.  I have a Nuvi 500 with this mount.  500 is waterproof.  I have ridden in the rain several times with it and no issues.  Google "Ram Mounts" and you will find all sorts of choices.  Stan
09/11/01 NEVER FORGET!
B
Capital Area - Michigan
« Reply #5 on: July 23, 2011, 08:34:09 PM »
FYI
Had mine mounted down there on a handlebar mount and could never see it in the daylight. I now have a ram mount at the brake lever bracket; it gives more versatility on angle and proximity. I still have to shade it with my hand on bright days but it is a vast improvement.
ptgb
Youngstown, OH
« Reply #6 on: July 23, 2011, 08:45:27 PM »
Here is what I did. Sometimes the sun will wash out the display but not that often. I showed it mounted on my Standard but transferred it later to my I/S with no problems.
http://www.valkyrieguy.com/gpsmount.htm
PhredValk
Edmonton, Alberta, Canada
« Reply #7 on: July 23, 2011, 10:40:10 PM »
I bought a Tomtom last Christmas during the sales for $88.00. Bought a weatherproof handlebar mount from Mountguys.com for $23.00. Clamped to the bars to the left of the riser bracket it works just fine. The shadow of the tank bag on long trips shades it from the sun, or I can tilt it down in the sun and it gets me there; mostly I use it for ETA and speedo. I'll mount it centre when I change to the Lamonster risers (no plate between the risers).
Fred.
VRCCDS0237
Colin
My old job
Orba, Spain
« Reply #8 on: July 23, 2011, 11:08:24 PM »
Shadow VT750 clamps fit right on and replace the 4 bolt clamp which frees up the space between the risers for adding additional items like a GPS.
Colin
VRCC Espana
My Bumble Bee re-build
Mr.BubblesVRCCDS0008
« Reply #9 on: July 23, 2011, 11:55:46 PM »
I bought my mount from these people. Very good customer support. www.semson.com  cooldude
« Reply #10 on: July 23, 2011, 11:57:50 PM »
It should have been www.sensons.com
Canuck
Palmetto Bay FL
« Reply #11 on: July 24, 2011, 05:53:15 AM »
I have the Zummo with supplied mount which works nicely but pricey.
I saw this on the Goldwing forum where a guy fabricated his own.  I think he could make a few bucks selling these.  You could always try a local machine shop.
Here is the link: http://www.goldwingfacts.com/forums/forum4/119156.html
Nice job!
Valkyrie ~ "chooser of the slain"
deadwood
Albuquerque New Mexico
« Reply #12 on: July 24, 2011, 07:41:01 AM »
I just mounted mine on the handle bar clamp with industrial strength velcro. Been there two years including Alaska and back. Peels right off when you want to remove it for the night.
Skydive New Mexico Motorcycle Club, Touring Division.
Firefighter
Harlingen, Texas
« Reply #13 on: July 24, 2011, 05:36:35 PM »
THANKS FOR ALL THE RESPONSES, GIVES ME NEW IDEALS TO CHOOSE FROM. REALLY WOULD LIKE TO MOUNT GPS IN THE MIDDLE LOW , AM CONCERNED ABOUT THE SUNLIGHT PROBLEM . STILL DECIDING,,, THANKS AGAIN!
1978 Honda 750
mikochan
Syracuse, NY
« Reply #14 on: July 25, 2011, 11:12:25 AM »
I mounted mine just to the right of the clamp. Used 1" ball mount with my Nuvi, sun not a problem most  of the time.
Cliff
Manchester, NH
« Reply #15 on: July 25, 2011, 11:24:30 AM »
RAM-B-367U
RAM MOTORCYCLE BASE W HOLE M8 SCREW
  replaces one of the screws holding the center plate down with a mounting ball that has a hole for the screw to go through to bolt the ball mount in place.!
VRCC # 29680
Promagnaman
North Dakota
« Reply #16 on: July 25, 2011, 11:30:53 AM »
Glarestomper.com has some nice gps shades...
kid4evr
Quincy, Mass
« Reply #17 on: July 27, 2011, 02:55:10 PM »
leadermotorcycles.com for the GPS mounting hardware and powerlet.com for the 12v cables which you attach to the battery. Works great.  I have a Nuvi 1490T on my Valkyrie and getting a bluetooth for the HJC helmet to hear it with.  Although if you don't have loud pipes I can hear it fairly well at speed.
paps350
Pittsburgh Pa
« Reply #18 on: July 27, 2011, 06:05:52 PM »
Go to Rammounts website and they have  any mount for any gadget you need to mount although some are a little pricey.
Michvalk
Remus, Mi
« Reply #19 on: July 27, 2011, 06:51:25 PM »
I bought my ram mount from mountguys.com. Good price and fast shipping cooldude
davekosh
Norton, MA
« Reply #20 on: March 19, 2012, 03:22:12 PM »
I got a Nuvi 665 for Christmas. I am mounting the unit with a ram mount. What can I do about mounting the antenna? The 665 antennna should be at least 6 iches away from the unit itself. ANY IDEAS??
GotValk
Champlin, MN
« Reply #21 on: March 19, 2012, 07:45:10 PM »
This Works for me!
Just take your time, put a blanket over your tank when you remove the caps and cover off and don't let your bars drop when you loosen it, I just drilled and tapped hole for my Ram ball mount.
« Last Edit: March 20, 2012, 02:07:49 PM by GotValk » Logged
