February 02, 2026, 11:08:49 PM *
Author Topic: Replacing Fork Oil  (Read 1378 times)
greggh
OMAHA NE
« on: July 24, 2011, 06:30:21 AM »
So I have decided to replace the oil in the Forks.
I did not disassemble the forks I only opent the tops of them and let them drain over night.
is it possible to just add the oil in the tubes or should I use a rubber hose to stick down inside the tubes and then add the fluid thru this hose.
I will be measuring the volume of the oil before adding so I get the proper amount of ounces in each tube.
Please advise!!
Thanks for your input.
Gregg
Dodis
'98 Blue & Cream
Texas City, TX
« Reply #1 on: July 24, 2011, 07:09:12 AM »
Gregg,
I am sure others will chime in and fill in any gaps I may leave, but since I just rebuilt my leaking right fork (again) last night...
Unless you totally take down the fork, there will still be enough residual oil that a volume measure may overfill the fork. Best bet is to use 1-2 oz less, then use a mighty-vac or big syringe with a measured hose to draw out oil down to the listed measurement.
As for filling, just pour the oil in as best you can, with a small funnel, or a thin stream taking your time.
See the chart below for the measurements for oil level, with fork fully compressed.
Mike "Dodis"
VRCC# 27132
mr_dodis(a)yahoo.com
DS#513 GY-TT 205/60   (still waiting for my cookie!)
greggh
OMAHA NE
« Reply #2 on: July 24, 2011, 12:11:39 PM »
I have added 22 oz to the right side the side with the Damper.
25 oz to the Left side.
Upon intial compression of the forks all seems rather uniform.
I guess a road test will be the ultimat tell tail.
More to come after monday after the res of the parts arrive.
Gregg
