February 02, 2026, 11:08:42 PM *
Author Topic: tire repair  (Read 1680 times)
N0tac0p
« on: July 26, 2011, 08:38:27 AM »
looking at different kits, dont know good / bad, but the new bike master looks pretty neat.  also how many cc's of co2 does it take to inflate the rear tire?
any thoughts friends?
« Reply #1 on: July 26, 2011, 09:32:50 AM »
I would go with the tiny 12v compressor, you can buy the repair kits with the plugs and handle about anywhere auto parts are sold. Hoser
Cliff
Manchester, NH
« Reply #2 on: July 26, 2011, 09:34:54 AM »
This inflation kit is very small and works well along with ANY tire plug kit.,,,, http://www.stopngo.com/products/Engine-Powered-Air-Pump-for-Motorcycles-%252d-5-ft-Hose-with-Quick%252dRelease-Lever.html
VRCC # 29680
Bugslayer
Lubbock, Texas
« Reply #3 on: July 26, 2011, 11:05:18 AM »
I have a "Stop & Go" tire plug kit. http://www.stopngo.com/products/Standard-Model-%252d-Tire-Plugger.html
 It's easy to use, and works well. I wouldn't use it for a permanent fix, but it'll get you off the side of the road. I agree with the compressor. A small 12v compressor (IMO) works better. Who knows.... You may have to add more air to a tire after fixing a road side flat to get you where you need to be.
N0tac0p
« Reply #4 on: July 26, 2011, 11:40:33 AM »
interesting, they don't  use any sealant?  certainly the reamer helps for a clean circle vs just plugging.  thx
« Reply #5 on: July 26, 2011, 01:48:29 PM »
I guess I just assumed you would use rubber cement with the plugs, my bad.  Hoser
John U.
Southern Delaware
« Reply #6 on: July 26, 2011, 06:06:10 PM »
The plug kits that Patchboy sells use vulcanizing mushroom plugs and rubber cement.
http://patchboy.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=P&Category_Code=ki
Tropic traveler
Silver Springs, Florida
« Reply #7 on: July 26, 2011, 06:31:13 PM »
My little 12v WalMart special compressor & some string plugs got this feller's UltraGlide back to the Harley shop for a new tire last summer. My cheapie string plugs left a bit to be desired but the Campbell Hausfield compressor worked real well 3 times.
It spit the string plugs out twice on the way back {about 25 miles} but it was worth the trouble as his tow service was 2-3 hours away!  Shocked
Anyways, I don't go on any decent length out of town trip without it ever!  cooldude
'13 F6B red for Kim
JetDriver
Columbus, OH
« Reply #8 on: July 26, 2011, 07:05:02 PM »
+1 (or 2 or 3  Smiley) on the 12v compressor.  Walmart/Target type stores will have them for $12-15, certainly less than $25.  I prefer the string plugs, rubber cement, reamer method over the mushroom plugs.  The one time I used a mushroom plug, it leaked.
