February 03, 2026, 02:16:37 AM *
Author Topic: IS Alternator question  (Read 2130 times)
tlh
« on: July 26, 2011, 04:14:41 PM »
I am trying to figure out if the Interstate came stock with an electrical noise suppressor on the alternator. I could pull off all my covers, take the ALT apart and look myself...but i am hoping to make it easier and see if someone has the answer for this.  this is about the noise suppressors that are required for the CB.
The noise suppressor that you have to add on as an accessory on the standard and tourer is marked in the diagram below as "Noise Suppressor C."   Is this part already on all our Interstates?
Bobbo
Saint Charles, MO
« Reply #1 on: July 26, 2011, 04:29:42 PM »
That part should be stock on all Interstates.  You can just look under the cover to see if it's on yours.
« Reply #2 on: July 26, 2011, 05:16:35 PM »
tlh, I know you want the answer for this question.
I never did see this item on my IS, but then, I never removed the alt from the motor, only the motor from the bike.
Now I know what I'm looking at/for in the future. I did find the info on the 2nd one for the CB from the manual on the Valk Norway site.
You should take your cover off and look. The alt cover is only held on by one bolt and some tabs. Be careful you don't break them when you take the cover off, and that you put the cover back on correctly. You'll know if the cover isn't on right.
Kingbee
VRCC# 576
Northern Illinois
« Reply #3 on: July 26, 2011, 06:24:06 PM »
It comes on the IS alternator, but looks different
1999 Interstate
2000 Interstate
2004 Rune
Rocketman
Seabrook, Texas
« Reply #4 on: July 26, 2011, 06:32:38 PM »
Yes, it's stock on an I/S.  However, if you buy the alternator, I don't think it will come with it.  I think it's separate from the alt.  It's held onto the back of the alt with one nut.  It is a black cube, ~3/4 inch per side.  You should be able to see it when the alt cover is removed.
Bone
« Reply #5 on: July 28, 2011, 10:45:36 AM »
I'm getting static in the speakers I put on my 98 Tourer.  I've looked on-line and can't find the noise filter. This morning I went to our bike shop that orders any parts I need and they are going to look for me they found nothing today.
Kingbee
VRCC# 576
Northern Illinois
« Reply #6 on: July 28, 2011, 11:10:47 AM »
Any shop that installs car stereos should be able to fix you up with something that works
1999 Interstate
2000 Interstate
2004 Rune
Bone
« Reply #7 on: July 28, 2011, 11:19:49 AM »
Thanks, my speakers came with a noise filter. The instructions gave 3 different ways to wire it noting that motorcycles ground through the frame. I tried each way taking a 5 mile ride after each change. Then went with the hook-up that sounded best to me.
I'm hoping for less static I'll keep looking.
« Reply #8 on: July 28, 2011, 12:15:46 PM »
Doesn't alternator noise sound like a whine that varies in pitch with engine speed, rather than sounding like a static hiss?
Alternator Whine!!!!powered by Aeva
Bone
« Reply #9 on: July 28, 2011, 12:41:09 PM »
Well I don't have a whine. Guess I was just going to throw filters at it until I got lucky. I appreciate the input this is a problem I've never had to deal with any sound system. Thanks.
« Reply #10 on: July 28, 2011, 01:11:25 PM »
Is the problem that the CB's squelch knob is not turned up enough?
Bone
« Reply #11 on: July 28, 2011, 03:21:39 PM »
Was away from the PC for an hour. Couldn't believe what I read   Embarrassed  I'm not a CB person but I knew you solved my problem with your question. Not for a second did squelch setting ever enter into my problem solving efforts. Took a 20 mile ride with my NEW sound and it's 90% now. Really good up to 45 mph at 60 mph I get some noise with the increased volume. I have my windshield tilted and get more wind noise. Not a real problem I will work on the adjustments.
Thank you so much. No way to know how much money I could have wasted and still have the same problem.
