March 25, 2026, 08:39:35 AM *
Author Topic: PAGING SWOPIE  (Read 1059 times)
« on: July 30, 2011, 03:40:41 PM »
You sold me a cb and antenna off your interstate but left out the left bracket and the wire from cb to bracket
I thought I was getting everything as I met your price
I have been to truck stops and radio shacks and can not locate a male to male cord and y splitter to try to adapt it to single antenna nor can I find a mount
so please take that now worthless left bracket  and hook up off your interstate and send it to me so I can actually finish hooking up the @#*$^$^# cb
Thank you
« Last Edit: July 30, 2011, 04:02:22 PM by Oss » Logged
« Reply #1 on: July 30, 2011, 06:30:49 PM »
Oss not knowing exactly what yer needing there are double male end adapters and double female end adapters. They are one piece units about an inch maybe a little better long. Should be sold in individual blister packs. Got em in my garage some where but i are in missouri. uglystupid2 Hope this helps. RIDE SAFE.
Highbinder
Bastian/Tazewell,VA.
« Reply #2 on: July 30, 2011, 07:38:44 PM »
Oss...I went down to Radio Shack yesterday and bought a splitter for my black I/S for $8 dollars and change, I didn't look for an extension cable because I didn't need one....it would seem to me living in a big city like NY you could find anything...but I guess not....they had one more splitter in stock that I saw, if you want I'll pick it up for you and check for an extension cable....by the way the cb and the radio work fine off the same antenna....in fact the cb transmits further now then before... cooldude
« Reply #3 on: July 30, 2011, 08:25:23 PM »
old2soon the y splitter has a male and 2 female ends if I remember correctly
the 3 to 4 feet of line I need to go from the splitter next to the battery under right cover to the cb lead under the trunk is a double male
it is not the cable like on the tv if you have one of these cb or remember the way antenna plugged into the slide out radio you had in your 60's car you know what i need
i hear ya don
the fella at radio shack went on their computer and couldnt find it
I even had taken off the side cover and shown him exactly where it went and also showed the end of the cb
a frustrating day indeed
but I aint givin up, not in my nature, just gonna bitch a bunch till its done
thanks for your help last week it was greatly appreciated
Highbinder
« Reply #4 on: July 31, 2011, 07:11:10 AM »
Evan...the splitter from Radio Shack is called the Universal Antenna Accessory part #40-uv44....I found it in the antenna section for car radio's, not in the cb area. that's where you're going to find the extension cable also...good luck.
