February 03, 2026, 12:40:42 AM
Stebel air horn wiring
Topic: Stebel air horn wiring (Read 1476 times)
Tibado
July 31, 2011, 01:28:38 PM »
The brief instructions that come with the Stebel Nautilus air horn are lacking. I want to use the existing horn button and wiring to trigger the relay. Is a drawing available?
Re: Stebel air horn wiring
July 31, 2011, 01:34:25 PM »
I did my own wiring when I got my stebil. The instructions were just fine, my horn button works. All you have to do is lengthen the two wires that used to go to the horn so they reach the relay and then just start plugging stuff in as teh little diagram shows, add a ground and it should be a go
Joe Hummer
Arnold, MO
July 31, 2011, 04:52:09 PM »
http://www.rattlebars.com/mtz/hornrelay.html
Hope this helps.
Joe
1999 Valkyrie Interstate
